PBP's default configuration for the 18F25K22 uses the Internal Oscillator for the Primary Oscillator.
So all you need to do is set the OSCCON register.
OSCCON = %01010000 ; 4Mhz
OSCCON = %01100000 ; 8Mhz
OSCCON = %01110000 ; 16Mhz
Or, if you enable the PLL with ...
OSCTUNE.6 = 1 ; Enable 4x PLL
Then ...
OSCCON = %01010000 ; 16Mhz
OSCCON = %01100000 ; 32Mhz
OSCCON = %01110000 ; 64Mhz
Make sure your DEFINE OSC matches.
