help with my calculator project
Results 1 to 2 of 2
    loayaouad's Avatar
    loayaouad Guest
    Default help with my calculator project
    I am currently working on a calculator project using the PIC16F84 and I need help with the overflow error detection when adding two 16 bit numbers
    Also I am facing problems with the multiplying of two 16 bit numbers
    To determine if the addition has overflowed... If the result is smaller than either of the original numbers, then it overflowed.
    V1      VAR  WORD
    V2      VAR  WORD
    Result  VAR  WORD
    Result = V1 + V2
    if Result < V1 then OverFlowed
    What problem are you having with Multiplying???
    Darrel
