I am attempting to interface the Parallax Ping ultrasonic sensor to a Pic16F876A. Here is the code:
I am using PBP 2.50B and Microcode Studio Plus v3. I pre-programmed the pic with the bootloader file provided im Microcode Studio Plus and using the ICD when executing the program.Code:Define LOADER_USED 1 Define OSC 20 dist var word loop: TRISB.7=0 low PORTB.7 PULSOUT PORTB.7,5 TRISB.7=1 pulsin PORTB.7,1,dist pause 100 goto loop end
When I observe the trigger and echo pulses with a oscilloscope I note that the width of the echo pulse is indeed proportional to the distance to the detected object . The problem is that the echo pulse isn't the 5V TTL pulse expected but only about 0.2 volts. Thus the width of the echo pulse isn't being measured and the variable dist is always set to zero. In my week long search of various forums the only two possibilities I have seen for this is that the sensor is either underpowered or the pin isn't being put into the input state. Now the documentation says that the Pulsin command makes the pin an input but just to be sure I added the TRISB.7=1 line just to be sure. I also verified that the voltage supplied to the ping sensor is 5V and it doesn't drop when it is in operation. I have also tested it on different pins and changed out the pic. Nothing works.
I have also tested the sensor using a Basic Stamp and operation is as expected. The echo pulse is a full 5V.
If the pic pin is being set to input then what reason could their be for the ping sensor to not be able to drive it to a logical high?
Any ideas? I am at my wits end.
Johnny K.
A frustrated physics teacher and robotics club leader
