pic 18Fxx31 PWM module
Results 1 to 4 of 4
    dirace's Avatar
    dirace Guest
    Default pic 18Fxx31 PWM module
    Is it possible to use the PWM modules of PIC 18Fxx31 uCs and how?
    Thanks in advance
    Hi, dirace
    Your answer is YES, using the HPWM function ( simpler ) , as they are supported by the 2.45 release , or using assembler ...a bit trickier.
    dirace's Avatar
    dirace Guest
    I use the following code:
    Define OSC 4
    hpwm 0,127,2000
    hpwm 1,127,1500
    go:
    Pause 50
    goto go
    This outputs PWM on RC1 and RC2 where CCP1 and CCP2 is and not on RB0 and RB1 where PWM0 and PWM1 is.
    And both signal are 1.5KHz!!!
    What am i doing wrong?
    Talking
    Just read manual : HPWM1 AND HPWM2 use the same clock ( TIMER 1) ...
    so, it's the same PWM frequency .... with PBP or Assembler !!!
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. how can i stop the pic from sending a PWM???
    By texas5 in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 18:12
  3. PWM Module 18Fxx31
    By iphillipsca in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 09:06
  4. Using PWM built in Module 16F628
    Last Post: - 9th October 2007, 07:40
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
