ADCin and floating point values
Results 1 to 4 of 4
    Italy
    Analog to Digital Converters (A/Ds)
    http://www.facstaff.bucknell.edu/mas...es/ConvAD.html
    Your ADC result will have NOTHING in common with floating point. Let me explain... assuming you have a 10-bit ADC, your minimum reading will be zero and your maximum reading will be 10-bits or 1024. This maximum reading is referenced to +VRef, and the minimum is referenced to -VRef.
    If -VRef is 0v, and +VRef is 5v, then 0v will equal zero on the ADC and 5v will equal a count of 1024. It goes to assume that 2.5v will be half of 1024 ie a count of 512, and 0.5v will have a count around 102...so you will have a resolution of about 5mV or 100 points on the scale.
    If you change your +VRef to 0.5v (keeping -VRef at 0v), then the scale will be between 0 and +VRef for your entire 10 bits... ie, a count of 0-1024 for a voltage range of 0-0.5v (here a resolution of 500uV).
    So to summarise, your ADC range is a count between -Vref and +Vref in the 10-bit (or 8-bit is you set it that way) resolution of your ADC. Thereafter you can perform some math on your ADC reading and thrrow in a decimal point to give you an answer in volts, amps, coulombs, whatever....
    Melanie
    niknaksbarbeque's Avatar
    niknaksbarbeque Guest
    Default Thanks
    Yes I was being thick, thank's very much for the replies guys, you've let me keep my hair (was slowly being torn out in clumps).
  1. Floating point math
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 04:47
