BCD to 7-segment issues
Results 1 to 6 of 6
    Jan 2012
    Grid EN19MV
    Default BCD to 7-segment issues
    I am driving a 7-segment display with an HC4511 BCD to 7-segment decoder.
    The input of the 4511 is connected to PORTB 0-3.
    I have a byte value that contains the number I want to display.
    Would something like this work?
    portB.0 = MyByte.Bit0
    portB.1 = MyByte.Bit1
    PortB.2 = MyByte.Bit2
    PortB.3 = MyByte.Bit3
    In other words, would the lower 4 bits of PORTB follow what my byte is doing? When I update my byte, would PORTB then change to reflect the new value? Or am I on the wrong track here?
    If I am on the wrong track, how do I make the lower 4 bits of PORTB mirror the lower 4 bits of my byte, without affecting the upper 4 bits of PORTB? The upper 4 are being used for other things.
    Andy
    PORTB = (PORTB & $F0) | (MyByte & $0F)
    Jan 2012
    Grid EN19MV
    Default Re: BCD to 7-segment issues
    Wow! So simple. I played with it on paper and that works great. I did have the idea of an OR in my head, but couldn't figure out how a bit that was set to a '1' could change back to a '0'.
    Actually, now that I think of it, since MyByte is only going to be zero to nine, I think I could get away with this:
    PORTB = (PORTB & $F0) | MyByte
    Thanks!
    It would be great, if someone with better PBP knowledge can explain, what that code actually does (how)
    Oct 2011
    Let us suppose bits 5 and 6 of portb are set and 4 is displayed on the 7 seg display and we want to display 5
    portb will be %01100100
    (portb & $F0) will clear the lower 4 bits of portb leaving bits 5 and 6 unchanged.
    01100100 &
    11110000
    01100000 result A
    (mybyte & $0F) will clear the top 4 bits of mybyte
    11000101 &
    00001111
    00000101 result B
    we now OR ( | ) result A with result B
    01100000 OR
    00000101
    01100101
    Bits 5and 6 of portb are unchanged and the lower 4 bits are set to 5
    If mybyte is never going to be greater than 9, (mybyte & $0F) can be replaced by mybyte
    See bitwise operators in the manual
    Thanks! So it is logical operation with pre-defined masks.
  1. Replies: 4
    Last Post: - 2nd November 2012, 09:47
  2. Multiplexing 7-Segment
    By ross246 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2011, 22:31
  3. Seven Segment LED
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 5th May 2011, 04:26
  4. interupt with 7-segment
    By freqout in forum mel PIC BASIC Pro
    Last Post: - 27th February 2010, 09:06
  5. keypad + 7-segment
    By evmav in forum mel PIC BASIC Pro
    Last Post: - 19th June 2006, 19:40
