Which pic? up to date basic chip for 16f877
Results 1 to 13 of 13
    Mar 2006
    China
    Default Re: Which pic? up to date basic chip for 16f877
    PIC18F4620 is a drop in replacable for the 877 but also have a look at the 18F46K20 since it is cheaper but it is a 3.3V device.
    may be this one would be really nice ???
    http://www.mikroe.com/eng/products/v...mini-32-board/
    Oh ... PBP Xtra still do not support 16 and 32 bits ???
    Poor me !
    Dec 2011
    IO93ok
    Hmm, thanks for the suggestions.
    Although, even on ebay the chips are relatively expensive. The cost of the chip is more than the rest of the components in the project !
    3 volt operation is no problem but I do need internal oscillator option and more I/O pins. Whereas the 877 and 877a don't offer the int osc option.
    It's not really a problem of code requirements more a problem of spurious rf, even when the crystal is mounted up close to the chip. I've tried the 628 in a similar design pcb as I want to use, this with internal osc and it is rf quiet. However external xtal on an 877 does generate more rf hash locally.
    Not very scientifically tested I'm sure but easily noticeable even with rf design techniques.
    For what I want to achieve I suppose I might as well go to two 628's rather than a single 40 pin device for cheapness. I just thought that there was a more modern version, without a cost penalty.
    The 4550 and 4620 both look attractive devices.
    Mar 2006
    China
    If you want low cost and internal osc you really should look into the 18F46K20 since it is much cheaper than the others and still have internal osc.
    A quick search on Microchip direkt shows that the 628A is around 2 USD and the 18F46K20 less than 3 usd..
    Being serious ...
    Why not consider the 16F887 ??? ... just intended to be the 877 successor ...
    and overall much cheaper than the 877 !!!
    Add to that ... OSCTUNE command to precisely trim your INTOSC ... he,he ...
    It is my personal opinion that everyone should stop using the OLD 16F's completely.
    If you've already designed something with them, they will be available for a long time, so keep building those products with the old stuff.
    But if you liked the 16F's, and are designing something new, move up to the 16F1 (enhanced core) devices.
    They are so much better than the OLD stuff.
    To replace a 16F877A, use a 16F1937.
    32Mhz Internal oscillator
    16 Level Stack
    16 channel Capacitive touch sensing module
    Integrated LCD controller
    5 CCP modules
    5 Timers
    A built in 555
    All the normal stuff too ... EUSART, MSSP, Comparators, ADC etc.
    Dec 2011
    IO93ok
    Wow, thanks Darrel that chip looks exciting.
    So many possibilities.
    Rob
  1. Single PIC to Blink 5 LEDs Independently?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 18th July 2015, 17:56
  2. Replies: 3
    Last Post: - 5th December 2008, 16:00
  3. RTC date problem
    By Peder in forum mel PIC BASIC Pro
    Last Post: - 19th January 2006, 13:33
  4. PIC Basic PRO 16F877 USART Interrupt TX
    By BigH in forum Serial
    Last Post: - 10th January 2006, 00:26
  5. calculate with date
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 14th October 2005, 17:49
