Infrared blink to Photoresistor
Results 1 to 6 of 6
    Mar 2006
    China
    Default Re: Infrared blink to Photoresistor
    I think you have missunderstood me a little.
    Pipes are great to use to build this kind of things. You should be aware that normal coloured PVC is transparent for IR so you will need to have either black PVC or paint the pipe.
    Of course you can try using a LED and a photo resistor. If it works in a reliable way good for you, if it doesnt there are a few options down the road that can help. Modulation is really simple to do if you have a HPWM and a mosfet transistor or just do the modulation in SW on any pin. The receiver for modulation you can usually harvest from any old remotecontrolled device. Look for a black little component with 3 legs.. TSOP48xx or 41xx or anything.. they will all detect a pulse if IR.
    Maybe your family has a DVD player that needs to be replaced with a Blueray ...
    Build the transmitter tube first and then you can see how far and big the beam becomes. If size is not a problem you can easily get more than 300m transmission range but then you need a proper lense. Big diameter and low magnification.
    Thank you very much for your help Jumper!!!
  1. Newbie with photoresistor problem
    By Karthik in forum Off Topic
    Last Post: - 26th March 2015, 20:53
  2. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 06:34
  3. Numeric value for Photoresistor/LDR value
    By tech in forum mel PIC BASIC Pro
    Last Post: - 16th February 2008, 01:54
  4. Photoresistor
    By atwoz in forum General
    Last Post: - 3rd January 2008, 19:15
  5. reading IR photoresistor
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 00:04
