Missing something ... But What ????
Results 1 to 5 of 5
    Default Missing something ... But What ????
    confused:
    I wrote a little Expanded scale Voltmeter program ...
    But I'm loosing my last hair on a little problem !
    Here's the program:
    'Voltmètre12.bas
    ' R/C Expanded scale Voltmeter
    ' Pic 12F1840
    ' 12 Multiplexed Leds
    ' 2 Display modes :
    ' - Jumper ON is Actual voltage BAR Display
    ' - Jumper OFF is Minimun reached Voltage in BAR Mode, plus Actual Voltage in DOT Mode
    ' ( intended to show Voltage swing under load )
    ' Defines
    DEFINE OSC 32
    'DEFINE
    ' Config
    	__CONFIG	_CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON
    	__CONFIG	_CONFIG2, _PLLEN_ON & _BORV_LO & _LVP_OFF
    OPTION_REG	= %10000001
    WPUA		= %00001000
    OSCCON 		= %11110000					' !!! SCS 1:0 = 00 pour PLL ON !!!
    INTCON 		= 0
    PIE1 		= 0
    T1CON 		= 0
    T1GCON		= 0
    CM1CON0		= 7
    ADCON0		= %00000001
    ADCON1		= %11100011
    FVRCON		= %11010011
    LATA 		= 0
    TRISA		= 255
    ' Aliases
    Modeselect 	VAR PORTA.3
    ' Variables
    Nvalue	VAR WORD
    Ivalue	VAR WORD
    Mvalue	VAR BYTE
    Dvalue 	VAR BYTE
    Value 	VAR BYTE
    I		VAR BYTE
    mode	VAR BYTE
    modeI	VAR BYTE
    CLEAR
    Mvalue = 12
    test:
    FOR Value = 1 to 12
    	Mode = 0 : ModeI = 0
    	GOSUB Display
    	PAUSE 200
    NEXT Value
    LATA	=	0
    Dvalue = 0
    BUTTON Modeselect,0,255,0,I,0,First				' Display actual Voltage
    ModeI = 1										' IF Jumper ON then Alternate mode
    First:											'
    ADCON0.1 = 1									'Launch First Conversion
    Wait0:
    FOR I = 1 to 16
    	IF ADCON0.1 = 0 THEN
    		Nvalue = ADRESH*256 + ADRESL			' read ADC result
    		GOTO Wait0
    	ADCON0.1	= 1								' relaunch conversion
    	Ivalue = (Ivalue*9 + Nvalue )/10			' First Value for Ivalue
    												' = True value for Mvalue !
    NEXT I
    WHILE 1
    Wait1:
    		GOTO Wait1
    	Ivalue = (Ivalue*9 + Nvalue )/10			' Rolling average
    	GOSUB Convert
    	IF Dvalue < Mvalue THEN Mvalue = Dvalue		' Memorize Minimum
    ' Prepare value to be displayed
    	IF ModeI == 1 THEN
    		FOR I = 0 to Dvalue						' Bar Display Actual value
    			Value = I
    			GOSUB Display
    		NEXT I
    		FOR I = 0 to Mvalue						' Bar Display Min Value
    			Value = I
    			GOSUB Display
    		NEXT I
    			Value = Dvalue						' Add Actual Value dot
    			GOSUB Display
    WEND
    Display:
    LATA = 0										'Prevent Ghosting
    LOOKUP Value,[%11111111,%11111001,%11111001,%11101101,%11101101,%11011101,%11011101,_
    			  %11101011,%11101011,%11011011,%11011011,%11001111,%11001111], TRISA
    LATA.1	= !!(value == 2)|| (value == 4) || (value == 6)
    LATA.2	= !!(value == 1)|| (value == 8) || (value ==10)
    LATA.4	= !!(value == 3)|| (value == 7) || (value ==12)
    LATA.5	= !!(value == 5)|| (value == 9) || (value ==11)
    PAUSE 1
    Convert:										'Convert ADC Counts to LED#
    LOOKDOWN2 Ivalue, < [513,526,538,551,563,576,588,601,613,626,638,651,663], Dvalue
    'Test purpose values set
    'LOOKDOWN2 Ivalue, < [551,563,576,588,601,613,626,638,651,663,676,688,700], Dvalue
    scheme joined.
    Everything could be Ok ...
    BUT
    in Default mode ( jumper OFF ) ... ONLY the Actual voltage is displayed by its dot : the minimum voltage doesn't appear ( the BAR )
    THIS section fails:
    			Value = I
    			GOSUB Display
    		NEXT I
    			GOSUB Display
    MPLAB SIM doesn't show anything strange, as it shows the BAR is simulated correctly ( timing also OK ...)
    So, ... I do not see what's wrong
    @ Darrel ... 12F1840 not supported by ISIS ... so, no more simulation solution
    Thanks to the one who will see anything ...
    Bombay, India
    Default Re: Missing something ... But What ????
    I suggest you try this modification. I think it will work.
    Jerson
    		GOTO Wait10
    	GOSUB Convert
    Wait10:
    Hi, Jerson
    Already had implemented Waiting loop while testing ... but conversion occurs while doing something else ... and has much enough time to be completed !
    after that, multiplexing leds doesn't allow dead times ...
    Bombay, India
    Hi Alain
    It is not about the conversion. Let me explain what I think could be the problem you see.
    When you are in ModeI=1, you are putting out a bar graph + a dot position. That is what I understand.
    What happens is when you are doing the bar graph, you are rapidly swiping the leds with the dot to enable your eyes to see a bar.
    After that happens, you wish to have another dot that stays on to represent the current reading. This too happens immediately after the bar is displayed; but, it happens after you erase the bar with LATA=0. Now, only the dot persists till the next time you refresh the display for bar and dot. This time between 2 display refreshes is tied to the delay for ADC in Wait1(your code).
    I choose to not wait for ADC, but process it when ready. Therefore the Wait10
    Jerson,
    I just commented the rolling average line
    replaced it by
    Ivalue = Nvalue
    ... and it began to work fine @ first run !!!
    that is somewhat incredible ...
    6 month ago, I wrote a similar program displaying on a couple of 7 segments : everything was fine.
    but I didn't use any average ...
    I do not understand that because the value was initialized with the average calculated just before entering the display loop ...
    Further tests look to show Nvalue = 0 @ first loop ( why ??? we are looping until a conversion result being available ... and it's ages the Pic ADC is stabilised ! ) : value is close to 9/10 Actual value, and then ... minimum value is generally under the minimum, and then not shown !
    that's how it should work ... but not why !
    I'll try to make further tests ...
  1. Missing a bit
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 19:54
  2. I've got to be missing something
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 19th July 2008, 01:27
  3. What am I missing????
    By cphillips82 in forum mel PIC BASIC Pro
    Last Post: - 15th July 2008, 15:03
  4. What am I missing here? If..Then
    By elevenscorpions in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2007, 04:06
  5. What am I missing
    By PaulB in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 17:15
