Missing something ... But What ????
Results 1 to 5 of 5
Threaded View
    Default Missing something ... But What ????
    confused:
    I wrote a little Expanded scale Voltmeter program ...
    But I'm loosing my last hair on a little problem !
    Here's the program:
    'Voltmètre12.bas
    ' R/C Expanded scale Voltmeter
    ' Pic 12F1840
    ' 12 Multiplexed Leds
    ' 2 Display modes :
    ' - Jumper ON is Actual voltage BAR Display
    ' - Jumper OFF is Minimun reached Voltage in BAR Mode, plus Actual Voltage in DOT Mode
    ' ( intended to show Voltage swing under load )
    ' Defines
    DEFINE OSC 32
    'DEFINE
    ' Config
    	__CONFIG	_CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON
    	__CONFIG	_CONFIG2, _PLLEN_ON & _BORV_LO & _LVP_OFF
    OPTION_REG	= %10000001
    WPUA		= %00001000
    OSCCON 		= %11110000					' !!! SCS 1:0 = 00 pour PLL ON !!!
    INTCON 		= 0
    PIE1 		= 0
    T1CON 		= 0
    T1GCON		= 0
    CM1CON0		= 7
    ADCON0		= %00000001
    ADCON1		= %11100011
    FVRCON		= %11010011
    LATA 		= 0
    TRISA		= 255
    ' Aliases
    Modeselect 	VAR PORTA.3
    ' Variables
    Nvalue	VAR WORD
    Ivalue	VAR WORD
    Mvalue	VAR BYTE
    Dvalue 	VAR BYTE
    Value 	VAR BYTE
    I		VAR BYTE
    mode	VAR BYTE
    modeI	VAR BYTE
    CLEAR
    Mvalue = 12
    test:
    FOR Value = 1 to 12
    	Mode = 0 : ModeI = 0
    	GOSUB Display
    	PAUSE 200
    NEXT Value
    LATA	=	0
    Dvalue = 0
    BUTTON Modeselect,0,255,0,I,0,First				' Display actual Voltage
    ModeI = 1										' IF Jumper ON then Alternate mode
    First:											'
    ADCON0.1 = 1									'Launch First Conversion
    Wait0:
    FOR I = 1 to 16
    	IF ADCON0.1 = 0 THEN
    		Nvalue = ADRESH*256 + ADRESL			' read ADC result
    		GOTO Wait0
    	ADCON0.1	= 1								' relaunch conversion
    	Ivalue = (Ivalue*9 + Nvalue )/10			' First Value for Ivalue
    												' = True value for Mvalue !
    NEXT I
    WHILE 1
    Wait1:
    		GOTO Wait1
    	Ivalue = (Ivalue*9 + Nvalue )/10			' Rolling average
    	GOSUB Convert
    	IF Dvalue < Mvalue THEN Mvalue = Dvalue		' Memorize Minimum
    ' Prepare value to be displayed
    	IF ModeI == 1 THEN
    		FOR I = 0 to Dvalue						' Bar Display Actual value
    			Value = I
    			GOSUB Display
    		NEXT I
    		FOR I = 0 to Mvalue						' Bar Display Min Value
    			Value = I
    			GOSUB Display
    		NEXT I
    			Value = Dvalue						' Add Actual Value dot
    			GOSUB Display
    WEND
    Display:
    LATA = 0										'Prevent Ghosting
    LOOKUP Value,[%11111111,%11111001,%11111001,%11101101,%11101101,%11011101,%11011101,_
    			  %11101011,%11101011,%11011011,%11011011,%11001111,%11001111], TRISA
    LATA.1	= !!(value == 2)|| (value == 4) || (value == 6)
    LATA.2	= !!(value == 1)|| (value == 8) || (value ==10)
    LATA.4	= !!(value == 3)|| (value == 7) || (value ==12)
    LATA.5	= !!(value == 5)|| (value == 9) || (value ==11)
    PAUSE 1
    Convert:										'Convert ADC Counts to LED#
    LOOKDOWN2 Ivalue, < [513,526,538,551,563,576,588,601,613,626,638,651,663], Dvalue
    'Test purpose values set
    'LOOKDOWN2 Ivalue, < [551,563,576,588,601,613,626,638,651,663,676,688,700], Dvalue
    scheme joined.
    Everything could be Ok ...
    BUT
    in Default mode ( jumper OFF ) ... ONLY the Actual voltage is displayed by its dot : the minimum voltage doesn't appear ( the BAR )
    THIS section fails:
    			Value = I
    			GOSUB Display
    		NEXT I
    			GOSUB Display
    MPLAB SIM doesn't show anything strange, as it shows the BAR is simulated correctly ( timing also OK ...)
    So, ... I do not see what's wrong
    @ Darrel ... 12F1840 not supported by ISIS ... so, no more simulation solution
    Thanks to the one who will see anything ...
  1. Missing a bit
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 19:54
  2. I've got to be missing something
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 19th July 2008, 01:27
  3. What am I missing????
    By cphillips82 in forum mel PIC BASIC Pro
    Last Post: - 15th July 2008, 15:03
  4. What am I missing here? If..Then
    By elevenscorpions in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2007, 04:06
  5. What am I missing
    By PaulB in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 17:15
