DT_Analog & 12F1822 internal voltage reference
Results 1 to 19 of 19
    Oct 2009
    Utah, USA
    Default Re: DT_Analog & 12F1822 internal voltage reference
    Darrel,
    More questions...
    In your sample code above why is the A/D conversion clock set to FRC??
    Does that mean some sort of external hardware RC oscillator?
    Can you please shed some light on choosing the A/D conversion clock?
    From your website example... it would seem that one should only choose FRC is if the PIC clock is running at 48MHz
    or does this table not apply to the 16F1822?
    Dwight
    Oct 2009
    Utah, USA
    So after doing some searching I found this... here... http://www.microcontrollerboard.com/...converter.html
    so now my question is...
    Is FRC just another way of saying Fosc/1 ?
    Is it not the case that Fosc/2 or Fosc/8 also come from the internal RC oscillator??
    Or is it the case that if one is using an external clock source for the PIC that you can either choose to divide the external clock source by 2, 8 or 32 (in the above example) or use the internal RC clock (FRC) for AD even though the PIC is clocked form an external source??
    Finally so far I have not had a need to run my projects faster than 4MHz and I just use the internal clock. So what is the best/correct AD clock source to use?
    Is it correct to read from the table on Darrel's AD page... if the OSC is running at 4MHz the best/correct choice is to use Fosc/8 ?
    Sorry for dragging this out so much... just trying to understand a little better.
    Dwight
    I don't think the enhanced cores were available yet when I wrote that page.
    The older chips had a minimum TAD of 1.6uS, but the newer ones have a minimum TAD of 1.0uS.
    So you could use the values in that table, but they will be off by 1 division from "Optimal" settings.
    If you look in the A/D section of the 1822 datasheet, you should see this table ...
    I've marked the best setting at each oscillator freq. in red.
    Put the matching ADCS bits into the ADCON1 register bits 4-6. DEFINE ADC_CLOCK does not have any effect on the enhanced core devices.
    The FRC clock is an internal RC oscillator that is separate from the main internal oscillator (FOSC).
    It continues running even when the PIC is put to SLEEP.
    It can be used at any OSC. But the actual TAD period can be anywhere from 1.0 - 6.0uS.
  1. Fixed Voltage Reference
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2012, 12:27
  2. ADC with reference voltage
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 22:01
  3. ADC - 2 channels but not same voltage reference - how to?
    Last Post: - 25th November 2007, 20:03
  4. COMPARATOR - Voltage Reference settings
    Last Post: - 9th October 2007, 08:06
  5. AD Negative Voltage reference
    Last Post: - 28th June 2007, 16:01
