VDIP1 Command List
Results 1 to 6 of 6
    Dec 2010
    Default VDIP1 Command List
    I'm interested in buying a VDIP1 so I can read some .txt files via pic chip, but I can't seem to find a list of commands to control the VDIP1 anywhere I look. I've seen things like "MKD" (make directory), "IPA" (input ASCII), "CD" (change directory), but nothing more than what I can find in example codes around the web. Could someone please post a link or download to where I can find the command list? Thanks.
    Default Re: VDIP1 Command List
    Look at
    VNC1L Firmware User Manual
    here
    http://www.ftdichip.com/Products/ICs/VNC1L.htm
    Dec 2010
    Once again mackrackit you've helped a lot, thank you. I've got one more question though. Most example codes I've seen are using SERIN and SEROUT, can I use HSERIN and HSEROUT instead?
    Yes, the VDIP uses TRUE mode.
    You have seen this?
    http://www.picbasic.co.uk/forum/show...highlight=vdip
    it is a very good example.
    Dec 2010
    Yes I have. That's where I got my examples from and it seems to be a very good article indeed. Well that should be it for now, I think I'll order a VDIP1 soon and see what I can do. Thanks again for all the help.
    Myron26's Avatar
    Myron26 Guest
    Thats fine ... but tell me one thing .. did your device get automatically detected by PC or needed to install drivers for the same ... i am working on it as my final year project so needed to sort this out as soon as possible
  1. VDIP1 (Vinculum - FTDI) problems
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 20th August 2013, 14:51
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Vdip1
    By sky071022 in forum Off Topic
    Last Post: - 9th March 2009, 04:42
  4. Replies: 0
    Last Post: - 6th March 2009, 08:52
  5. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 18:02
