how? 2 wire lcd with pbp?
Results 1 to 24 of 24
    Sougata,
    I checked your attachment and I noticed something odd. The LCD is parallel, it's the communication to the PIC that is serial.
    Or am I more confused than I think I am?
    Feb 2005
    Kolkata-India
    Default It is a normal LCD with a dedicated PIC for serial com
    Hi there,
    Parallel LCDs are easily available and cheaper (at least here in India). The SELD is a dedicated PIC programmed with PBP that drives a normal parallel LCD. The PIC takes its command via a serial input thus freeing up resources on the main controller.
    I personally use a PIC18F452 based circuit that uses interrupt based serial routine handling and gives me the freedom to use buttons and indicators at the same time. A complete user interface module you can say. This reduces wiring in my panel from the main coontroller and leaves the controller more useful for other sensing and control tasks.
    Sougata
  1. lcd stops after about 5 minutes and gets stuck
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 15th September 2009, 12:03
  2. one wire
    By karenhornby in forum General
    Last Post: - 18th June 2008, 20:24
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 00:13
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
  5. 2 decimal display on LCD
    By pt3rg in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 14:28
