Hi there,
Parallel LCDs are easily available and cheaper (at least here in India). The SELD is a dedicated PIC programmed with PBP that drives a normal parallel LCD. The PIC takes its command via a serial input thus freeing up resources on the main controller.
I personally use a PIC18F452 based circuit that uses interrupt based serial routine handling and gives me the freedom to use buttons and indicators at the same time. A complete user interface module you can say. This reduces wiring in my panel from the main coontroller and leaves the controller more useful for other sensing and control tasks.
Sougata
