how? 2 wire lcd with pbp?
Results 1 to 24 of 24
    May 2005
    Default how? 2 wire lcd with pbp?
    is it possible to use shiftout with 2 wire lcd configuration? or do we have to shift the datas and strobe the data and clock pins manually
    i'm not sure of your of your actual LCD but more than often they use simple serial communication @2400/4800/9600 bauds. Use Hserout or Serout statement.
    P.S.: for all your future post, please include more details.. part #, web link, provider or any info you have. That help us to give you the right answer.
    May 2005
    thnx for replying mister e. sorry for the lack of information... wat i eamnt was a 2 wire lcd using a using a shift register 74ls174 wic uses a datapin and a clockpin... http://www.rentron.com/Myke1.htm i think predko did it. i've seen melanie showing a same example too but wondering if someone could show me is it possible to use shiftout with this circuit and sending a LCDOUT string.
    Smile
    HI,
    Another solution is using an I2C device like the PCF 8574 ...that allows bus sharing.
    Italy
    I think the questions are:
    Can I redirect the output of the PicBasic LCDOUT command to my 2-Wire LCD Interface?
    (I am using an LCD module with a Hitachi 44780 controller or equivalent).
    Would I have to write my own LCD routines in order to use my 2-Wire LCD Interface?
    Luciano
    I do recall posting this a couple of years back... you will have to use SHIFTOUT or similar commands to drive it.
  1. lcd stops after about 5 minutes and gets stuck
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 15th September 2009, 12:03
  2. one wire
    By karenhornby in forum General
    Last Post: - 18th June 2008, 20:24
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 00:13
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
  5. 2 decimal display on LCD
    By pt3rg in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 14:28
