PBP3 Long setup
Results 1 to 4 of 4
Thread: PBP3 Long setup
    Default PBP3 Long setup
    Hi all, I'm just getting started with PBP3(I've used 2.47 in the past) and it's been a while since I've programmed.
    I was trying to use the LONG feature for my 18F2331. Where/how exactly do I enter the -n to get it to work?
    Any help much appreciated.
    Thanks!
    Default Re: PBP3 Long setup
    If you're using MicroCodeStudio as your IDE then all you need to do is click View -> Compile and Program Options and make sure that the option Use Compiler Long Words (18 series MCU only) is ticked.
    If you're compiling from the commandline then that is where you enter the -n option, ie PBPX -n -p18F45K20 myProgram.pbp or something like that.
    Thanks for the reply,
    I'm using MPLAB v8.85. As mentioned above, it's been a while and I'm not sure where the commandline entry would go.
    I did look at the PBP3 inc file but I'm still not sure if that's where it goes or not.
    Ian
    Ok, found it.
    There's the tab for Project/Build options in MPLAB. And low and behold there's a check box in the PBP tab.
    Just in case anyone else is looking.
  1. Just updated from 2.60C to PBP3!!!!
    By MarioC in forum General
    Last Post: - 11th April 2012, 05:42
  2. PBP3 and MCSP
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 25th March 2012, 15:44
  3. I really need some help with PBP3
    By Ramius in forum mel PIC BASIC Pro
    Last Post: - 26th February 2012, 16:05
  4. Pbp3
    By rcbandwidth in forum mel PIC BASIC Pro
    Last Post: - 18th September 2011, 14:13
  5. What's with PBP3?
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 10th August 2011, 17:09
