This was tested on a PIC18F25J11 running at 3V, but should work on your 46J11. Note it was tested with PBP3, but can easily be modified to work with earlier versions.
It produces a very accurate 1Hz clock out on RB1.Code:#CONFIG CONFIG OSC = INTOSC CONFIG LPT1OSC = OFF CONFIG CP0 = OFF CONFIG WDTEN = OFF CONFIG XINST = OFF CONFIG IOL1WAY = OFF CONFIG STVREN = OFF CONFIG T1DIG = OFF CONFIG FCMEN = OFF CONFIG WDTPS = 512 CONFIG RTCOSC = T1OSCREF #ENDCONFIG ' Connect a 32.768 kHz watch crystal between pins 11 & 12 T1CKI & T1OSI ' with caps to match your crystal capacitance. ' 11 12 ' |---||---| ' | xtal | ' _|_ _|_ ' ___ ___ 2 x 12pF caps ' | | ' gnd gnd DEFINE OSC 4 OSCCON = %01100000 ' using 4MHz internal osc ' // disable A/D & setup Timer1 for RTCC // ANCON0 = $ff ANCON1 = $1f ' disable A/D on all analog pins T1CON = %10001101 ' ext 32.768 kHz xtal, 1:1 prescale, no synch, 8-bit, timer1 on TRISB.1 = 0 ' clear TRISB.1 for RTCC 1Hz output PADCFG1 = %00000010 ' RTCC seconds clock is selected for output on the RTCC pin RTCCFG.2 = 1 ' set RTCC output enable bit EECON2 = $55 ' unlock sequence to enable writes to RTCC registers EECON2 = $AA RTCCFG.5 = 1 ' set bit 5 for RTCC write enable RTCCFG.7 = 1 ' set bit 7 for RTCC clock enable EECON2 = $55 ' lock sequence to disable writes to RTCC registers EECON2 = $AA RTCCFG.5 = 0 ' clear bit 5 to lockup & disable RTCC writes Here: GOTO Here END
This is a working test version of a serial clock & 3 x 10KHz PWM outputs with the same PIC CLOCK_25J11.txt
Hope this helps.
