Rtcc
Results 1 to 5 of 5
Thread: Rtcc
    Jun 2008
    Chicago suburb
    Default Rtcc
    I have not programmed a pic for several years.
    I want to use a 18F46J11 and I want to use the
    on chip RTCC as a free running 1 sec timer
    with the RB1 port giving me every sec an output
    (0.5s on 0.5s off). This is from the spec sheets.
    In my design I have a 32.768 kHz crystal on the
    Timer1 external clock input Pin RC0/RC1.
    How do I initiate the timer in PBP?
    Any help is greatly appreciated, however my
    feedback how things worked out will have to
    wait a bit since I am currently laying out the pcb
    and I have to know if I have to make changes
    to my design.
    Thank you for your help
    Gerd
    Default Re: Rtcc
    I am not familiar with that chip, but for the timer I would use DT's Instants
    http://darreltaylor.com/DT_INTS-18/home.html
    And do you really layout the PCB before testing on a breadboard? You are braver than me
    Jun 2008
    Chicago suburb
    Default Re: Rtcc
    thanks for the link but I don't want to use interups since the accuracy is not important.
    I just want the 1 sec rtcc output.
    I may have written poorly in my initial request but I do breadbord before finishing the
    pcb. I do temporary lay-outs to see how everything fits.
    Gerd
    Default Re: Rtcc
    This was tested on a PIC18F25J11 running at 3V, but should work on your 46J11. Note it was tested with PBP3, but can easily be modified to work with earlier versions.
       CONFIG OSC = INTOSC
       CONFIG LPT1OSC = OFF
       CONFIG CP0 = OFF
       CONFIG WDTEN = OFF
       CONFIG XINST = OFF
       CONFIG IOL1WAY = OFF
       CONFIG STVREN = OFF
       CONFIG T1DIG = OFF
       CONFIG FCMEN = OFF
       CONFIG WDTPS = 512
       CONFIG RTCOSC = T1OSCREF
      ' Connect a 32.768 kHz watch crystal between pins 11 & 12 T1CKI & T1OSI
      ' with caps to match your crystal capacitance.
      ' 11        12
      '  |  xtal  |
      ' _|_      _|_
      ' ___      ___  2 x 12pF caps
      ' gnd      gnd
      OSCCON = %01100000  ' using 4MHz internal osc
      ' // disable A/D & setup Timer1 for RTCC //
      ANCON0 = $ff
      ANCON1 = $1f        ' disable A/D on all analog pins
      T1CON = %10001101   ' ext 32.768 kHz xtal, 1:1 prescale, no synch, 8-bit, timer1 on
      TRISB.1 = 0         ' clear TRISB.1 for RTCC 1Hz output
      PADCFG1 = %00000010 ' RTCC seconds clock is selected for output on the RTCC pin
      RTCCFG.2 = 1        ' set RTCC output enable bit
      EECON2 = $55        ' unlock sequence to enable writes to RTCC registers
      EECON2 = $AA
      RTCCFG.5 = 1        ' set bit 5 for RTCC write enable
      RTCCFG.7 = 1        ' set bit 7 for RTCC clock enable
      EECON2 = $55        ' lock sequence to disable writes to RTCC registers
      EECON2 = $AA
      RTCCFG.5 = 0        ' clear bit 5 to lockup & disable RTCC writes
    Here:
      GOTO Here
    It produces a very accurate 1Hz clock out on RB1.
    This is a working test version of a serial clock & 3 x 10KHz PWM outputs with the same PIC CLOCK_25J11.txt
    Hope this helps.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2008
    Chicago suburb
    Default Re: Rtcc
    Bruce
    Thank you very much for your help. I had internet problems on my home computer
    so could not receive your response over the weekend. I am using now my work computer.
    I am going to try it out and I believe the onboard rtcc is the same on all 18F chips.
    Thanks again and best regards
    Gerd
  1. Mcp79410 rtcc
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 17th July 2012, 05:36
  2. 18F devices RTCC Interrupt
    By readitaloud in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 10:39
  3. Support for RTCC
    By fowardbias in forum PBP Wish List
    Last Post: - 28th April 2011, 16:49
  4. 18F25J11 RTCC & remappable pin options
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2011, 10:20
  5. 18F25J11 RTCC & remappable pin options
    Last Post: - 26th February 2011, 10:51
