Serin,Serout Problem
Results 1 to 16 of 16
Threaded View
  1. #15
    Oct 2012
    Default Re: Serin,Serout Problem
    Quote Originally Posted by orwell101 View Post
    Hello!
    I think i must send the CHR$ code of a.
    How can i do this?
    I don't think so. By limiting the decimal value of 'a' to printable characters, the byte being sent will print that ASCII character. So, the way its being sent now is '32' will print a space, '33' will print "!",,,, '65' will print "A", etc..
    Are you willing to try separate and different ports for the SERIN and SEROUT? Sending and receiving on the same port pin is something I've never seen done using SERIN and SEROUT... and I have never considered doing it myself. It sure would eliminate one obvious anomaly.
    <snip...>
    SI var PORTB.7
    start:
    SERIN si,N2400,B0 <===== SERIN (on) PORTB.7
    if b0 <> "0" then
    for a= 32 to 126
    serout si,N2400,[a] <====== serout (on) PORTB.7
    Try not using the same port for SERIN and SEROUT.
    It may not be an issue for PBP to use the same port pin, but I can't imagine what the hookup to the RS232 would look like.
    EDIT: To be simple about it, just remark out:
    start:
    ' SERIN si,N2400,B0
    ' if b0 <> "0" then
    for a= 32 to 126
    serout si,N2400,[a]
    next a
    ' endif
    goto start
  1. Serin and Serout problem
    By rubisharmax in forum mel PIC BASIC Pro
    Last Post: - 10th June 2012, 13:20
  2. problem with serout and serin 2
    By amtechnology in forum General
    Last Post: - 14th May 2012, 13:08
  3. Another Serin/Serout Problem!
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 16:26
  4. Serin serout problem
    Last Post: - 6th February 2007, 04:25
  5. serout and serin problem
    Last Post: - 11th April 2006, 19:44
