Serin,Serout Problem
Results 1 to 16 of 16
    Oct 2012
    Default Serin,Serout Problem
    Hello!
    I am a Newbie on programming Micros.
    I have a PIC 16F84 an wrote a littele Program.
    This is my Programm:
    INCLUDE "modedefs.bas"
    B0 var byte
    a var byte
    SI var PORTB.7
    start:
    SERIN si,T2400,B0
    if b0 <> "0" then
    for a= 0 to 255
    serout si,T2400,[a]
    next a
    goto start
    When i send an X in the serial communicator window,the PIC sould send
    the complette ASCII codes.
    But the PIC send this:
    X!A9#T̑!3H!CR"ʒ*Sq҉f2cRbr j(PPb=RiQQfy}-RR**-Mm*
    Xq-1=AMQ]amq}*``
    !"#,-./0123<=>?@ABCLMNOPQRS\]^_`abclmnopqrs|}~ *
    The Settings of then Serial Communicator is:
    COM1
    2400 Baud
    NoParity
    ByteSice 8
    1 Stop Bit
    What do i wrong?
    I think its a little Problem for the most afl here.
    Sorry for mx English(german)
    Thanks a lot for your help!
    Default Re: Serin,Serout Problem
    Welcome to the forum.
    Try Inverted mode.
    From the manual
    While single-chip RS-232 level converters are common and inexpensive, the excellent I/O specifications of the PICmicro allow most applications to run without level converters. Rather, inverted input (N300..N9600) can be used is conjunction with a current limiting resistor.
    Dec 2010
    Lots of possible error sources, including, most likely, clock configuration. Please post your complete code.
    Are you using something like a MAX232 device? If not, you need to invert your data.
    Oct 2012
    Quote Originally Posted by Charlie View Post
    I'm having a similar problem with my project and I was told to ensure the data sent was true (not inverted). I am using a 16f88, not an 84 maybe that's the difference?
    Dec 2010
    Quote Originally Posted by harralk View Post
    Why don't you simply try it? It's a grand total of 1 character difference in 2 places in the posted code... Certainly no need to take our word for it
    Feb 2011
    Michigan, USA
    Serial out and serial in on same PIC pin? Normally separate pins.
    Quote Originally Posted by orwell101 View Post
    Hello!
    B0 var byte
    a var byte
    SI var PORTB.7
    start:
    SERIN si,T2400,B0
    if b0 <> "0" then
    for a= 0 to 255
    serout si,T2400,[a]
    next a
    goto start
    X!–ˆA9Œ#‘T‘!†Ž3’H!CR‰"’*Sq‰fœ2cRbr‚’ j(PPb=RiQQfy}-RR**™-Mm*
    –Xq-1=AMQ]amq}‘*˜``
    !"#,-./0123<=>?@ABCLMNOPQRS\]^_`abclmnopqrs|}~€‚ƒŒŽ‘’“œžŸ *
    COM1
    2400 Baud
    NoParity
    ByteSice 8
    1 Stop Bit
    What do i wrong?
    That you get output is good, that it is garbage can have several causes. 1 oscillator is not defined in code, 2. baud rate mismatch between sender & receiver. 3. sending and receiving mismatch (one true the other inverted). 4. long or loss-ey cables causing data corruption, or receiving noise.5.mismatched data profile I E parity # of bits . . .
    I would DEFINE OSC x where x represents your crystal or resonator, or if you are using INTRC then make (x) 4. The define does not make the oscillator work at that speed it simply forces PBP to adjust all of it's timing to accommodate the defines speed.
    Oct 2012
    Hello!
    I have used DEFINE OSC 4
    and N9600.
    I think the Problem is my COM Settings.
    What shoul i use there?
    Oct 2012
    I know how frustrating it can be to get this problem. It cost me several hours (and a dead USB to RS232 dongle) to isolate my problem. It turns out the internal oscillator (4Mhz) on my 12F629 was too far off. I probably killed the internal calibration value by mistake at some other time.
    "for a= 0 to 255"
    You are getting some data in acceding order. Using printable characters can help by counting the number of correct ascending order before it breaks consistent order. The control characters can be muddying up things. Maybe:
    for a=32 to 126 'send only printable characters
    Also, characters pacing might help
    DEFINE CHAR_PACING 1000 'character pacing of 1ms
    My Hyper Terminal setting is on ASCII (chosen from a list in the setup)
    In your code, change back to 2400
    N2400
    And leave the PC program at 2400.
    Let us know what happens so we can help more if needed.
    Oct 2012
    Hello!
    I have tried this.
    B0 var byte
    define OSC 4
    A var byte
    SI var PORTB.7
    start:
    SERIN si,N2400,B0
    if b0 <> "0" then
    for a= 32 to 126
    serout si,N2400,[a]
    next a
    goto start
    And the PIC sends nothing more
    Oct 2012
    It stops sending anything? Or the same garbage? Which?
    And I'm with Mike:
    "Serial out and serial in on same PIC pin? Normally separate pins. "
    Oct 2012
    Hello!
    I think i must send the CHR$ code of a.
    How can i do this?
    About half way down is the Standard ASCII Character Set
    http://melabs.com/resources/ascii.htm
    Oct 2012
    Hello!
    How can i do this?
    I don't think so. By limiting the decimal value of 'a' to printable characters, the byte being sent will print that ASCII character. So, the way its being sent now is '32' will print a space, '33' will print "!",,,, '65' will print "A", etc..
    Are you willing to try separate and different ports for the SERIN and SEROUT? Sending and receiving on the same port pin is something I've never seen done using SERIN and SEROUT... and I have never considered doing it myself. It sure would eliminate one obvious anomaly.
    <snip...>
    SI var PORTB.7
    start:
    SERIN si,N2400,B0 <===== SERIN (on) PORTB.7
    if b0 <> "0" then
    for a= 32 to 126
    serout si,N2400,[a] <====== serout (on) PORTB.7
    Try not using the same port for SERIN and SEROUT.
    It may not be an issue for PBP to use the same port pin, but I can't imagine what the hookup to the RS232 would look like.
    EDIT: To be simple about it, just remark out:
    start:
    ' SERIN si,N2400,B0
    ' if b0 <> "0" then
    for a= 32 to 126
    serout si,N2400,[a]
    next a
    ' endif
    goto start
    Sep 2010
    Las Vegas, NV
    If that doesn't work try
    start:
    ' SERIN si,N2400,B0
    ' if b0 <> "0" then
    for a= 32 to 126
    serout si,T2400,[a]
    next a
    ' endif
    goto start
    I believe if the issue is only with inverted data that should get it to display.
  1. Serin and Serout problem
    By rubisharmax in forum mel PIC BASIC Pro
    Last Post: - 10th June 2012, 13:20
  2. problem with serout and serin 2
    By amtechnology in forum General
    Last Post: - 14th May 2012, 13:08
  3. Another Serin/Serout Problem!
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 16:26
  4. Serin serout problem
    Last Post: - 6th February 2007, 04:25
  5. serout and serin problem
    Last Post: - 11th April 2006, 19:44
