Single PIC to Blink 5 LEDs Independently?
Results 1 to 40 of 69
    Default Re: Single PIC to Blink 5 LEDs Independently?
    (If this is bad etiquette to re-open a 1-yr old thread then I'll start a new one)
    Well, what was working (I think) last year isn't this year as I prepare to move this to production with a SMT version of the 12F683. The blinking still works but the brightness control doesn't - no matter what the values are for Brightness all 5 LEDs appear to not change (they're still way too bright).
    '*  Name    : Nacelle_Blinking_Lights_12F683_8Mhz_Int.pbp       *
    '*  Author  : Ross A. Waddell                                   *
    '*  Notice  : Copyright (c) 2015                                *
    '*  Date    : 06/30/2015                                        *
    '*  Version : 3.0                                               *
    '*  Notes   : Blinking nacelle engine lights (TOS Enterprise)   *
    ' Nacelle engine lights
    ' (a) The colours used were: red, blue, green, amber and pink, all standard
    '     colours they had for common Christmas lights of the time.
    ' (b) They were all C7 Christmas lights (too big for a 1/350). 12 by my guess.
    ' (c) Amber was steady (5 in a star pattern), all the rest blinked.
    ' For production version of this code, update config fuses to
    ' enable code protect (CP_ON)
    ' Basic blinky code provided by Darrel Taylor
    ' See forum posting here:
    ' http://www.picbasic.co.uk/forum/showthread.php?t=17299&p=116934#post116934
    ' Pin Connections
    ' GP5    -> pin 2             -> R4 -> BL4
    ' GP4    -> pin 3             -> R5 -> BL5
    ' GP3    -> pin 4             -> MCLR (input only, 'dummy' BL6)
    ' GP2    -> pin 5             -> R1 -> BL1
    ' GP1    -> pin 6             -> R2 -> BL2
    ' GP0    -> pin 7             -> R3 -> BL3
    ' Initialization
    ' If not using the MCLR pin as in input, there is no need to add an external resistor to tie it
    ' to VDD if the PIC has an internal pull-up. See http://www.picbasic.co.uk/forum/archive/index.php/t-872.html
    ' MCLR=OFF means that MCLR is handled INTERNALLY and that pin can be used for I/O (Input actually).
    ' Whatever you do to the pin in this instance will have no bearing on the PIC running or not. It will
    ' be just another INPUT pin. You could leave it floating if it was unused.
      __config  _INTOSCIO & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    DEFINE OSC 8
    OSCCON     = %01110000     ; 8MHz internal osc
    ANSEL      = 0             ; All Digital
    CMCON0     = 7
    TRISIO     = 0             ; all OUTPUT
    OPTION_REG = %00000110     ; Timer0 prescaler 1:128
    TMR0IF   VAR INTCON.2      ; Timer0 Overflow bit
    ;----[ MIBAM Setup ]---------------------------------------------
    wsave       var byte    $70     SYSTEM  ' Alternate save location for W
    ssave       VAR BYTE    BANK0   SYSTEM  ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM  ' location for PCLATH register
    BAM_COUNT CON 5                     ; How many BAM Pins are used?
    ;DEFINE BAM_INFO 1
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    Bright  VAR BYTE[BAM_COUNT]
    Br0     VAR Bright[0]
    Br1     VAR Bright[1]
    Br2     VAR Bright[2]
    Br4     VAR Bright[3]
    Br5     VAR Bright[4]
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (GPIO,0, Br0)          ;   and the associated Duty variables
         BAM_PIN (GPIO,1, Br1)
         BAM_PIN (GPIO,2, Br2)
         BAM_PIN (GPIO,4, Br4)
         BAM_PIN (GPIO,5, Br5)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    ;----[Setup Blinky parameters]-----------------------------------
    DEFINE BLINKYFREQ 100                ; 10mS periods
    LEDcount    CON 5                    ; Number of LEDs on the PORT
    ;                BL3,BL2,BL1,BL5,BL4 ; PCB indicators
    OnTimes     DATA  50, 22, 50, 75, 17 ; default periods for each Output
    OffTimes    DATA 150, 45, 50, 95, 22
    ; Blinky on/off info from older code
    '                 BL3,BL2,BL1,BL5,BL4
    ;OnTimes     DATA  50 ,22 ,50 ,75 ,17; default "on" periods for each output
    ;OffTimes    DATA 150 ,45 ,50 ,95 ,22; default "off" periods for each output
    ;#IFDEF USE_RANDOM_SEQUENCE            ; randomization
    ;    RND     VAR WORD : RND = 13864
    ;    MIN_ON  CON 220                   ; Minimum random ON time
    ;    MAX_ON  CON 333                   ; Maximum random ON time
    ;    MIN_OFF CON 33                    ; Minimum random OFF time
    ;    MAX_OFF CON 275                   ; Maximum random OFF time
    ;    RandPeriod VAR WORD[LEDcount]
    ;    RandPeriods DATA WORD 1000, WORD 1250, WORD 1500, WORD 1750, WORD 2000
    ;#ENDIF
    ; Adjust values below for the 5 blinkies re: brightness
    Brightness  DATA 5,5,5,5,5
    #DEFINE USE_RANDOM_SEQUENCE         ; comment for contiuous Sequence
        MIN_ON  CON 50                  ; Minimum random ON time
        MAX_ON  CON 500                 ; Maximum random ON time
        MIN_OFF CON 50                  ; Minimum random OFF time
        MAX_OFF CON 500                 ; Maximum random OFF time
    #ENDIF
    ;----[Variables used only by Blinky]-----------------------------
    LoopLED    VAR WORD[LEDcount]
    OnTime     VAR WORD[LEDcount]
    OffTime    VAR WORD[LEDcount]
    x          VAR BYTE
    temp       VAR WORD
    speed      CON 6
    ;----[Initialize]------------------------------------------------
    FOR x = 0 to (LEDcount - 1)         ; load the periods from EEPROM
        READ OnTimes+x, OnTime(x)
        READ OffTimes+x, OffTime(x)
            READ RandPeriods+(x<<1), WORD RandPeriod(x)
        #ENDIF
    NEXT X
    ;----[Main Program Loop]-----------------------------------------
        x = (x + 1) // LEDcount
        IF LoopLED(x) < OnTime(x) THEN
            READ Brightness + x, temp
            IF Bright(x) < temp THEN
                Bright(x) = Bright(x) + speed
                Bright(x) = temp
            IF Bright(x) > 0 THEN
                Bright(x) = Bright(x) - speed
                Bright(x) = 0
        LoopLED(x) = (LoopLED(x) + 1) // (OnTime(x) + OffTime(x))
            RandPeriod(x) = RandPeriod(x) - 1
            IF RandPeriod(x) = 0 THEN
                RANDOM RND
                OnTime(x) = (MAX_ON - MIN_ON)* RND.HighByte / 255 + MIN_ON
                OffTime(x)= (MAX_OFF - MIN_OFF)* RND.LowByte / 255 + MIN_OFF
        #ENDIF
        IF x != (LEDcount - 1) THEN Main
    Waiting: IF !TMR0IF THEN Waiting
        TMR0 = 99
        TMR0IF = 0
    GOTO Main
    As you can see, I haven't implemented Darrel's most recent suggestion (probably because a year ago this was working OK).
    Any ideas?
    Went back through my versioning of the code and found that the previous one works just fine - I must've made some tweaks in v3 that screwed things up. I'll need to go through them line-by-line to see where the discrepancy is (if only for my own benefit).
    Here's the working code:
    '*  Notice  : Copyright (c) 2014                                *
    '*  Date    : 03/25/2014                                        *
    '*  Version : 2.0                                               *
    ' (a) The colours used were: red, blue, green, amber and pink, all standard colours
    '     they had for common Christmas lights of the time.
    ' (b) They were all Christmas lights (C7, too big for a 1/350). 12 by my guess.
    ' Pin Connections
    ' Initialization
    DEFINE OSC 8
    CMCON0     = 7
    ;----[ MIBAM Setup ]--------------------------------------------------------
    ;DEFINE BAM_INFO 1
    Br0     VAR Bright[0]
    Br1     VAR Bright[1]
    Br2     VAR Bright[2]
    Br4     VAR Bright[3]
    Br5     VAR Bright[4]
    OnTimes     DATA  50, 22, 38, 75,  5 ; default periods for each Output
    OffTimes    DATA 150, 45, 38, 95, 34
    Brightness  DATA 255,10,10, 10, 255
    #ENDIF
    x          VAR BYTE
    FOR x = 0 to LEDcount - 1         ; load the periods from EEPROM
        #ENDIF
    NEXT X
            READ Brightness + x, Bright(x)
            Bright(x) = 0
                RANDOM RND
        #ENDIF
        TMR0 = 99
        TMR0IF = 0
    GOTO Main
    After going through the two different versions I remembered that the last thing I wanted to implement was varying the brightness of each LED to ramp up/off to the set BRIGHTNESS level. This would simulate incandescent bulbs by 'fading' up the LED (and also fade off).
    This is the suspect code:
    temp       VAR WORD
    speed      CON 6
        #ENDIF
    NEXT X
                Bright(x) = temp
                Bright(x) = 0
                RANDOM RND
        #ENDIF
        TMR0 = 99
        TMR0IF = 0
    GOTO Main
  1. Single button function
    Last Post: - 4th April 2020, 19:33
  2. How to blink 8 LEDs at different rates- concurrently?
    By rmteo in forum mel PIC BASIC Pro
    Last Post: - 27th April 2010, 00:47
  3. single sided PCB
    By schu4647 in forum General
    Last Post: - 10th December 2008, 19:22
  4. Can't Blink 2 LEDs
    By dfort in forum mel PIC BASIC
    Last Post: - 5th March 2008, 23:36
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
