Where can i ask re asm programming problem with bcd subtraction
Results 1 to 5 of 5
    Dec 2011
    IO93ok
    Default Re: Where can i ask re asm programming problem with bcd subtraction
    Thanks Mike,
    Unfortunately I've already tried that routine but nothing changes. I've tried looking for my error but I'm now dizzy with it.
    As it's a direct step before sending the byte to the LCD i assumed it should at least mess up the display tens digits.
    The 'tens' value are in just one BCD packed byte.
    I have the code working as a direct rf signal generator using one of the cheap ebay dds boards. Total cost of parts about 10 pounds sterling.
    I would like to utilise it as a vfo for a homebrew rig but displaying 0 on the display when the dds is giving out 9mhz. The dds and display would then track up in tandem. This would match the 'i f' then.
    It seems a shame to start again with PBP when I have full working asm code. I may just try to get the 'freq word' out to the dds using PBP in a test situation.
    Rob G4NQX
    Aug 2005
    Michigan, USA
    Hi Rob,
    I wouldn't mind taking a closer look. Can you post a sample five byte packed BCD frequency value? Also, are you using a fixed or absolute address for the five byte frequency variable? And, are you subtracting a "constant" 9000000 value or will that be a variable value?
    Regards, Mike, K8LH
    Dec 2011
    IO93ok
    Hi Mike,
    Apologies, I've been away a few days.
    I've sent you a PM including my email address, so as not to clutter up the forum.
    Rob G4NQX
  1. Help - programming problem!
    By George in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2010, 13:52
  2. Programming Problem PIC12F683
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2009, 22:39
  3. Re-Programming Problem
    Last Post: - 5th April 2009, 02:25
  4. Addition and subtraction
    Last Post: - 25th January 2008, 15:24
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 01:02
