i cant comment on the code much , but its a bit easier to read
Code:Temperature: i2cread SDA, SCL, SAdef, LocAmbTemp, [AmbTemp] 'read amb temperature Ta & save in AmbTemp gosub SwapAmbBytes: 'I2C reads the highest byte first; Go swap the bytes i2cread SDA, SCL, SAdef, LocObjTemp, [ObjTemp] 'read object temperature (Tobj) & save in ObjTemp gosub SwapObjBytes: if AmbTemp >= ObjTemp then Temperature 'Object is not heating, continue to loop if (ObjTemp - AmbTemp) >= ThresTemp then ObjHeating 'differance between Amb & Obj temperature has exceeded threshold temp Reset: 'Reset time count and turn motion sensor off if (ObjTemp - AmbTemp) is less that threshold temp. cnt = 1 low 6 'turns motion sensor off goto Temperature ObjHeating: high 6 'obj is heating; turn motion detector on (by setting RB6 high) to check for motion in room . for cnt = 1 to MaxTime 'measure time by counting # of loops of approx one sec each. If portb.1 = 1 then Temperature 'motion occured in room, do a reset i2cread SDA, SCL, SAdef, LocAmbTemp, [AmbTemp] 'read amb temperature Ta & save in AmbTemp gosub SwapAmbBytes: i2cread SDA, SCL, SAdef, LocObjTemp, [ObjTemp] 'read object temperature (Tobj) & save in ObjTemp gosub SwapObjBytes: if AmbTemp >= ObjTemp then Temperature 'Object is not heating, start new loop if (ObjTemp - AmbTemp) < ThresTemp then Temperature 'differance between Amb & Obj temperature is less than threshold temp next cnt Alarm: 'object temperature has exceeded threshold temp for more than the MaxTime, so sound alarm high portb.0 pause 2000 low portb.0 pause 15000 if portb.5 = 0 then Temperature goto Alarm end ' ---------- Sub Routines ---------- SwapAmbBytes: 'swap the MSB and LSB of the amb and obj temperatures swap AmbTemp.byte1, AmbTemp.byte0 return SwapObjBytes: swap ObjTemp.Byte1, ObjTemp.byte0 return
