Fet for turning on high voltage.
Results 1 to 15 of 15
Threaded View
  1. #6
    Default Re: Fet for turning on high voltage.
    I think this is what you want.
    Maybe you have to check the values of R6, R7 to ensure Vgs of the P-Mosfet is within safe limits.
    Name:  P-Mosfet driver.png
    Also you can replace the N-Mosfet with a BC337 and a 1K base resistor. But I think the proposed schematic is more elegant and fast without gate resistor (direct PIC connection). The P-Mosfet for my application is low Rds and much more Amperes than what you need. So, maybe, you have to choose another one.
    My selection on R6, R7 was with speed to consumption priority and with these values they should be at least 1/2W. If you can live with smaller speed, or you only need ON/OFF case, then select higher values, but always make sure you give P-Mosfet gate the correct voltage levels.
  1. High voltage transistor
    By Ioannis in forum General
    Last Post: - 8th March 2011, 16:30
  2. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 12:50
  3. High Voltage Danger? When?
    By manumenzella in forum Schematics
    Last Post: - 29th November 2007, 09:50
  4. High freq, low voltage - what happens if?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 02:36
  5. turning gpio.0 high after pwm command
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 19:22
