can someone help
Results 1 to 5 of 5
    scumari's Avatar
    scumari Guest
    Default Re: can someone help
    After receiving those two from Ebay, I started programming a routine.
    This is a working two way communication routine:
    '* Name : nRFLarge.BAS *
    '* Author : SCUMARI Tec *
    '* Notice : Copyright (c) 2013 SCUMARI Group *
    '* : All Rights Reserved *
    '* Date : 1-6-2013 *
    '* Version : 1.0 *
    '* Notes : PIC18LF13K50 controller for the NRF24L01+ RF module *
    '* : This is standard software for both sender and receiver. *
    '* : Both module start in receive mode. When the button is pressed,*
    '* : a byte is randomized ans send over by two bytes. Both recei- *
    '* : ver and sender displays the value on a LED bar. *
    ' PIC18LF13K50
    ' ___ ___
    ' VDD O|1 - 20|O VSS
    ' RA5 OSC1 OSCIN O|2 19|O RA0 + PGD
    ' RA4 AN3 OSC2 CLKOUT O|3 18|O RA1 D- PGC
    ' RA3 MCLR VPP O|4 17|O VUSB
    ' RC5 CCP P1A T0CKI O|5 16|O RC0 AN4 C12IN+ INT0 VREF+
    ' RC4 P1B C12OUT SRQ O|6 15|O RC1 AN5 C12IN1- INT1 VREF-
    ' RC3 AN7 P1C C12IN3- PGM O|7 14|O RC2 AN6 P1D C12IN2- CVREF INT2
    ' RC6 AN8 SS T13CKI T1OSCI O|8 13|O RB4 AN10 SDI SDA
    ' RC7 AN9 SDO T1OSCO O|9 12|O RB5 AN11 RX DT
    ' RB7 TX CK O|10 11|O RB6 SCK SCL
    '18F14K50
    @ __CONFIG _CONFIG1L, 000h
    @ __CONFIG _CONFIG1H, 018h
    @ __CONFIG _CONFIG2L, 000h
    @ __CONFIG _CONFIG2H, 000h
    @ __CONFIG _CONFIG3H, 080h ;080h is MCLRE
    @ __CONFIG _CONFIG4L, 000h
    @ __CONFIG _CONFIG5L, 003h
    @ __CONFIG _CONFIG5H, 0C0h
    @ __CONFIG _CONFIG6L, 003h
    @ __CONFIG _CONFIG6H, 0E0h
    @ __CONFIG _CONFIG7L, 003h
    @ __CONFIG _CONFIG7H, 040h
    INCLUDE "modedefs.bas"
    DEFINE OSC 16
    DEFINE SHIFT_PAUSEUS 100
    OSCCON = 118 '4550 op $FE / K50 op 118 / 689 op 112
    OSCTUNE = 31 '4550 op $0F / K50 op 31 / 689 op 15
    ADCON0 = 0
    ANSEL = 0
    ANSELH = 0
    UCON = 0
    IOCA = 3
    IOCB = 0
    INTCON = 0
    PORTA = 0
    TRISA = %00111111
    PORTB = 0
    TRISB = 0
    PORTC = 0
    TRISC = 0
    sck VAR PORTB.4
    miso VAR PORTA.4
    irq VAR PORTA.1
    mosi VAR PORTB.5
    scn VAR PORTB.6
    ce vAR PORTB.7
    butt var PORTA.0
    addr var byte
    addr1 var byte
    addr2 var byte
    addr3 var byte
    addr4 var byte
    addr5 var byte
    addrm var word
    temp VAR word
    tmp VAR BYTE
    indatl VAR BYTE
    indath VAR BYTE
    outdatl VAR BYTE
    outdath VAR BYTE
    i VAR BYTE
    pype var byte
    cnt var byte
    'Times
    tlong con 100
    tmid con 50
    tshort con 25
    scn = 1
    sck = 0
    ce = 0
    PORTC = 129
    pause 50
    PORTC = 66
    pause 50
    PORTC = 36
    pause 50
    PORTC = 24
    pause 50
    PORTC = 24
    pause 50
    PORTC = 36
    pause 50
    PORTC = 66
    pause 50
    PORTC = 129
    pause 50
    PORTC = 0
    indatl = 0
    init:
    addr = %11100010 : gosub ComWrite 'Flush RX
    addr = %11100001 : gosub ComWrite 'Flush TX
    addr = 32 + 7 : outdatl = %01000000: gosub ConfWrite 'Clear RX_DR, TX_DS and MAX_RT
    'Set PWR_UP to 1 (00.1)
    'MASK_RX_DR = 0 (00.6)
    'MASK_TX_DS = 1 (00.5)
    'MASK_MAX_RT = 1 (00.4)
    'Set PRIM_RX to 1 for receive (00.0)
    addr = 32 + 1 : outdatl = %00000001 : gosub ConfWrite 'ENAA_Px
    addr = 32 + 2 : outdatl = %00000001 : gosub ConfWrite 'ERX_Px
    addr = 32 + 5 : outdatl = 40 : gosub ConfWrite 'RF_CH
    addr = 32 + 6 : outdatl = $0F : gosub ConfWrite 'RF_SETUP
    addr = 32 + 17 : outdatl = 2 : gosub ConfWrite 'RX_PW_P0
    addr1 = $E1: addr2 = $E2: addr3 = $E3: addr4 = $E4: addr5 = $E5
    addr = 32 + 10 : gosub ADDRWrite 'RX_ADDR_P0
    'addr1 = $E1: addr2 = $E2: addr3 = $E3: addr4 = $E4: addr5 = $E5
    'addr = 32 + 11 : gosub ADDRWrite
    'outdatl = $E1
    'addr = 32 + 15 : gosub ConfWrite
    addr = 32 + 16 : gosub ADDRWrite 'TX_ADDR
    ' 'Read back config
    ' for i = 0 to 9
    ' PORTC = i
    ' pause 500
    ' addr = i : gosub statRead
    ' PORTC = indatl
    ' pause 1000
    ''init2:
    '' if butt = 1 then init2
    ' next i
    ' addr = 10 : gosub AddrRead
    ' PORTC = addr1
    ' pause 500
    ' PORTC = addr2
    ' pause 500
    ' PORTC = addr3
    ' pause 500
    ' PORTC = addr4
    ' pause 500
    ' PORTC = addr5
    ' pause 500
    ' addr = 16 : gosub AddrRead
    ' PORTC = addr1
    ' pause 500
    ' PORTC = addr2
    ' pause 500
    ' PORTC = addr3
    ' pause 500
    ' PORTC = addr4
    ' pause 500
    ' PORTC = addr5
    ' pause 500
    ' 'goto init
    addr = 32 : outdatl = %00111111 : gosub ConfWrite 'Start receiving
    'Set CE to 1
    ce = 1
    pauseus 200
    if butt = 0 then gosub Transmit
    if irq = 0 then gosub Receive
    Transmit:
    ce = 0
    addr = 32 : outdatl = %00111110 : gosub ConfWrite 'PRIM_RX = 0
    random temp
    PORTC = temp : outdatl = temp : outdath = temp
    addr = %10100000 : gosub DataWrite 'send TX_PLD
    pauseus 100
    Trans0:
    ce = 1
    PAUSEUS 200
    ce = 0
    Trans1:
    addr = 7 : gosub statRead
    if indatl.4 = 0 then Trans2 'Read MAX_RT
    addr = 32 + 7: outdatl = %00100000: gosub ConfWrite 'Clear MAX_RT
    goto trans0
    Trans2:
    if indatl.5 = 0 then Trans1 'Read TX_DS
    addr = 32 + 7: outdatl = %00100000: gosub ConfWrite 'Clear TX_DS
    addr = 32 : outdatl = %00111111: gosub ConfWrite 'Set PRIM_RX to 1
    ce = 1
    Receive:
    ce = 0
    addr = %01100001 : gosub DataRead
    PORTC = indath
    pause 200
    PORTC = indatl
    addr = 32 + 7: outdatl = %01000000: gosub ConfWrite 'Clear RX_DR
    ce = 1
    ComWrite:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    scn = 1
    ConfWrite:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    for tmp = 0 to 7
    mosi = outdatl.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    outdatl = outdatl << 1
    pauseus tmid
    next tmp
    ' SHIFTOUT mosi, sck, 1,[addr]
    ' SHIFTOUT mosi, sck, 1,[outdatl]
    ' pauseus tshort
    scn = 1
    StatRead:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    pauseus tshort
    indatl = 0
    for tmp = 0 to 7
    indatl = indatl << 1
    sck = 1
    pauseus tmid
    indatl = indatl + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    ' SHIFTOUT miso, sck, 1,[indatl]
    ' pauseus tshort
    scn = 1
    AddrWrite:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    for tmp = 0 to 7
    mosi = addr1.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    addr1 = addr1 << 1
    pauseus tmid
    next tmp
    for tmp = 0 to 7
    mosi = addr2.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    addr2 = addr2 << 1
    pauseus tmid
    next tmp
    for tmp = 0 to 7
    mosi = addr3.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    addr3 = addr3 << 1
    pauseus tmid
    next tmp
    for tmp = 0 to 7
    mosi = addr4.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    addr4 = addr4 << 1
    pauseus tmid
    next tmp
    for tmp = 0 to 7
    mosi = addr5.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    addr5 = addr5 << 1
    pauseus tmid
    next tmp
    ' pauseus tshort
    scn = 1
    AddrRead:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    pauseus tshort
    addr1 = 0
    for tmp = 0 to 7
    addr1 = addr1 << 1
    sck = 1
    pauseus tmid
    addr1 = addr1 + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    addr2 = 0
    for tmp = 0 to 7
    addr2 = addr2 << 1
    sck = 1
    pauseus tmid
    addr2 = addr2 + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    addr3 = 0
    for tmp = 0 to 7
    addr3 = addr3 << 1
    sck = 1
    pauseus tmid
    addr3 = addr3 + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    addr4 = 0
    for tmp = 0 to 7
    addr4 = addr4 << 1
    sck = 1
    pauseus tmid
    addr4 = addr4 + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    addr5 = 0
    for tmp = 0 to 7
    addr5 = addr5 << 1
    sck = 1
    pauseus tmid
    addr5 = addr5 + miso
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    scn = 1
    DataWrite:
    scn = 0
    pauseus tshort
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    for tmp = 0 to 7
    mosi = outdatl.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    next tmp
    for tmp = 0 to 7
    mosi = outdath.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    outdath = outdath << 1
    pauseus tmid
    next tmp
    ' 'FILL with zeroos
    ' for tmp = 0 to 15
    ' mosi = 0
    ' pauseus tshort
    ' sck = 1
    ' pauseus tmid
    ' sck = 0
    ' pauseus tmid
    ' next tmp
    ' SHIFTOUT mosi, sck, 1,[outdath]
    pauseus tshort
    scn = 1
    DataRead:
    scn = 0
    for tmp = 0 to 7
    mosi = addr.7
    pauseus tshort
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    addr = addr << 1
    next tmp
    pauseus tshort
    indatl = 0
    for tmp = 0 to 7
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    next tmp
    pauseus tshort
    indath = 0
    for tmp = 0 to 7
    indath = indath << 1
    sck = 1
    pauseus tmid
    indath = indath + miso
    sck = 0
    pauseus tmid
    next tmp
    scn = 1
    Have fun.
