Weird PWM Behaviour on 16F1825
Results 1 to 15 of 15
    Default Weird PWM Behaviour on 16F1825
    It's possible I'm losing my mind, but why would this code make my motor spin faster than the revised code below? Everything else is the same (code, config, circuit connections).
    Sample code 1 (motor spins up to correct RPM, from Test_SN754410_Reverse_0):
    HIGH MOTOR_2_DIR         ' reverse
     ' Spin up motors to saved value of _MotorRPM
    IF MotorRPM > 66 THEN
        FOR I = (255-65) to (255-MotorRPM) step -1
            pause 30
            HPWM 2, I, 20000  ' port engine (CCP2)
        NEXT I
    EndIf
    HPWM 2, 255-MotorRPM, 20000' port engine (CCP2)
    Sample code 2 (motor spins up to a lower RPM regardless of initial value of PortEngDir, from Test_SN754410_Reverse_1):
    PortEngDir           VAR BYTE
    PortEngDir = 1
    if PortEngDir = 1 then
                pause 30
            NEXT I
        EndIf
        LOW MOTOR_2_DIR          ' Forward
            FOR I = 65 to (MotorRPM - 1)
                pause 30
            NEXT I
        EndIf
        HPWM 2, MotorRPM, 20000  ' port engine (CCP2)
    Is there something about nested IF blocks I don't know about?
    Default Re: Weird PWM Behaviour on 16F1825
    What's weird is that the code in the Main loop is the same, but if I program the same PIC16F1825 chip with the 2nd file (Test_SN754410_Reverse_1) then the motor spins at the lower RPM as it does in the IF..ELSE..ENDIF block before Main.
    Anyone have any ideas? Ultimately, I'm modifying the program to allow using a switch to control motor direction but I don't want to lose how the motors spun with the previous code (as in Test_SN754410_Reverse_0)
    Anyone? A correction to the above is that the faster RPM is **not** what I want - I think this a cause of my EEPROM variable getting a weird initial setting of greater than what I have in the code (possibly linked to my post here).
    In both cases it defaults to
    So it will always go to the second IF in the nest.??
    But the direction of the motor should be different (if you're talking about the 2nd sample code). Could it be that with additional code lines somehow the chip isn't being completely erased before re-programming so the EEPROM variable is some number > 255?
    You should check the settings on your programmer.
    I set them back to default after reading a post from Darrel on the EE_Var thread, but that hasn't helped. Which settings in particular are you thinking of?
    Erase code, erase eeprom settings for starters.
    I had checked those earlier, Demon, and also selected the 'Set to default'. I'll look over those again tonight.
    Here's a screenshot of my settings:
    I think you are interested in 3 things in particular: erasing before programming, programming and erase options.
    Here are my settings:
    Name:  Programmer options 1.JPG
    Name:  Programmer options 2.JPG
    Quote Originally Posted by RossWaddell View Post
    ... Could it be that with additional code lines somehow the chip isn't being completely erased before re-programming so the EEPROM variable is some number > 255?
    What if you display the eeprom value to an LCD or send it out to PC via RS232?
    It would help to eliminate that as the source of your problem.
    Ross, what about your Program settings?
    I have the same settings except I also have the 'User ID' checked/enabled.
    Problem resolved. I was updating DT_INST-14.bas directly for different chips based on instructions for earlier versions of the file; now that I've downloaded the latest version and added the variables to my main program as needed, it seems to work fine.
  1. Config & Oscon settings 16F1825
    Last Post: - 9th July 2020, 17:18
  2. Interrupt On Change Question on 16F1825
    Last Post: - 23rd August 2012, 05:05
  3. Convert Rotary Encoder Code from 16F628A to 16F1825
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 04:34
  4. PBP3 Support HPWM on CCP3/CCP4 (16F1825)?
    Last Post: - 3rd June 2012, 01:37
  5. odd 2550 behaviour
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 7th November 2006, 09:03
