16F877 Flickering LED
Results 1 to 17 of 17
    XT_OSC is used for 4MHZ crystal/oscillator speed. HS_OSC is used for crystal/oscillator over 4MHZ. The default setting is XT_OSC. There's no difference for a PIC to see ceramic resonator or crystal... since it generate pulses.
    So in your case you'll have to change it to HS, in the .INC file or as i suggest, comment the config lines in your .INC file and place all fuses setting in your code. Really handy.
    Red face Still Nothing
    Hi Steve
    I have done the following:
    Edit C:\pbp\16F877.INC, Replace _XT_OSC to _HS_OSC
    And edit my code as followings:
    Include "Modedefs.bas"
    DEFINE OSC 20 ' Set the Xtal frequency to 20mHz
    RFVDDPin VaR PORTA.3 ' RF Module Power Pin.
    ADCON1 = 7 ' Set Analog pins to Digital.
    TRISA = 0 ' Set all PortA Pins as output
    high RFVDDPin ' Switch RF Module On.
    here:
    goto here
    But with no luck, it is still flickering?
    is the actual circuit is on a bread board? If so try removing the capacitor around your crystal and post your result. Also, 0.1 uF capacitor sould be as close as you can of the PIC and of the RF module betwenn VDD and GND.
    what about if you change your resistor from RF module otput to VDD? If the problem is still there, what about if you remove your RF module?
    Red face Circuit
    It's doing this in my circuit as well as in the bread board.
    I have also connect my Crystal and caps directly to the 40 pin ic socket and not through the bread board's holes.
    Although if I connect the RF Module directly to the 5volt and GND of my circuit, it is working, but as soon as I connect them to the Pic's Pin, it starts flickering?
    Smile Found the Problem
    Thank you all for your feedback, I have found my problem.
    I'm feeling like an idiot, the Transistor was the wrong way arround.
    Some datasheets show it one side around and other datasheet the other way arround?
    It was strange because I have measured 5v @ 49mA when it was the wrong way arround.
    Steve, thank you with all your patience!!
    Hehe it happen
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Replies: 3
    Last Post: - 5th December 2008, 15:00
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
