Depending of your actual code but... did you disable internal adcs?ADCON1=7
set PORTA.3 to outpuit, set here to LOw at the begining?
are you sure of your actual schematic? looks weird.. What is the part number of your RF module?
Here is my code:
Include "Modedefs.bas"
DEFINE OSC 20 ' Set the Xtal frequency to 20mHz
RFVDDPin VaR PORTA.3 ' RF Module Power Pin.
ADCON1 = 7 ' Set Analog pins to Digital.
TRISA = 0 ' Set all PortA Pins as output
high RFVDDPin ' Switch RF Module On.
by using end this make your pic to stop or goto lalaland IMHO.
what aboutalso be sure you set the oscillator configuration fuse to HS.Code:DEFINE OSC 20 ' Set the Xtal frequency to 20mHz ADCON1 = 7 ' Set Analog pins to Digital. TRISA = 0 ' Set all PortA Pins as output RFVDDPin VaR PORTA.3 ' RF Module Power Pin. Main: high RFVDDPin ' Switch RF Module On. here: goto here
"also be sure you set the oscillator configuration fuse to HS."
How do I do this?
in your PIC programmer software or into your code
click here to know set fuse into your code
be sure you have a PIC who can handle the 20Mhz clock. PIC16F877-20
Is _XT_OSC for a Crystal, because that is what I am using and that is what the Inc file's default is?
XT_OSC is used for 4MHZ crystal/oscillator speed. HS_OSC is used for crystal/oscillator over 4MHZ. The default setting is XT_OSC. There's no difference for a PIC to see ceramic resonator or crystal... since it generate pulses.
So in your case you'll have to change it to HS, in the .INC file or as i suggest, comment the config lines in your .INC file and place all fuses setting in your code. Really handy.
