On Interrupt Goto (for pic18f252 ) Help
Results 1 to 5 of 5
    disable al interrupts:
    INTCON=0
    reenable... use the one you declare at the begining:INTCON = $a0 ' Enable TMR0 interrupts
    also don't forget to add Enable after Resume
    Here's what you need. i'm using the internal USART @2400 baud.
        '    Pic define
             ' Using PIC18F2320
             define LOADER_USED 1
        '    Hardware definition
             TRISB=0
             TRISC=%10000000
        '    Interrupt definition
             T0CON  = %11010101
             On Interrupt Goto  Gettime
        '    Serial Communication definition
             DEFINE HSER_TXSTA 24h
             DEFINE HSER_RCSTA 90h
             DEFINE HSER_BAUD 2400
        '    I/O alias definition
             PowerLED  VAR PORTB.5 'Pin 26 Red
             StatusLED VAR PORTB.4 'Pin 27 Green
        '    Variable definition
             hour   var byte ' Define hour variable
             minute var byte ' Define minute variable
             second var byte ' Define second variable
             ticks  var byte ' Define pieces of seconds variable
             Delay  var word
             CLEAR
    RsetAll:
        toggle PowerLED 'RED LED
             '    Delay loop
                  for delay =1 to 10000
                      pauseus 10
                      next
        goto RsetAll
        '    Interrupt routine to handle each timer tick
    disable  ' Disable interrupts during interrupt handler
    Gettime:
        ticks = ticks + 1 ' Count pieces of seconds
        If ticks < 59 Then T1Exit ' 61 ticks per second (16.384ms per tick)
        '    One second elasped - update time & display
             ticks = 0
             second = second + 1
             If second >= 60 Then
                second = 0
                minute = minute + 1
                If minute >= 60 Then
                   minute = 0
                   hour = hour + 1
                   Endif
                write 43,hour
                write 44,minute
                write 45,second
                Endif
             hSerOut [#hour,":",#minute,":",#second,13,10]
        T1Exit:
               INTCON.2=0 ' clear interrupt flag
    Resume
    enable
    Forget about the INTCON stuff i said before..
    P.S. By writing to internal EEPROM as often as you do, you'll burn it soon, You should consider the use of external EEPROM like FRAM OR by saving your data only when the Voltage goes bellow a certain threshold. For cheapness i'll use the last option.
  1. RC Servo decoding/encoding using 12F683
    By ScaleRobotics in forum Code Examples
    Last Post: - 14th September 2010, 01:49
  2. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
