16F88 using comparators AND the adc
Results 1 to 3 of 3
    jpeakall's Avatar
    jpeakall Guest
    Default 16F88 using comparators AND the adc
    Hi All,
    A brief outline of what I am working on:
    The PIC will recieve a signal using the onboard comparators. I loop and look for the state of the comparator until it hits. Timer 1 is running and uses the intterupt for a timeout if the signal is not recieved.
    Now what I want to do is use the ADC right after the comparator hits and measure the voltage on a cap to determine signal strength (its a 40kHz ultrasonic signal, amplified by an op amp and fed into the comparators) so as to position my sensor in the best location.
    From reading the spec sheets and browsing the archive on the 'F88, I gather that there are issues using both the adc and the comparators at the same time. Before I pound my head silly, I thought I'd run it past y'all and see if this is what I should do:
    init the comps
    wait for signal
    disable the comps
    enable the adc
    get the signal
    Or, is it possible to have to comps turned on and the the adc turned on, using only of course the channels not used by the comps?
    As always, thanks!
    Jonathan
    You can setup one single ended comparator with RA1 & RA2, then use
    RA0 or RA3 for A/D inputs.
    @ DEVICE HS_OSC, CCPMX_ON, MCLR_OFF, LVP_OFF, WDT_OFF
        ' CCPMX_ON = PWM ON B.3, CCPMX_OFF = PWM ON B.0
        DEFINE OSC 20
        DEFINE HSER_BAUD 19200
        Comp    VAR BYTE
        AD        VAR WORD
        Symbol  COUT = CMCON.7  ' Comparator C2OUT bit
    Init:
        ANSEL = %00001111    ' RA0 to RA3 A/D function
        ADCON0 = %10000001  ' Channel 0, A/D Frc osc, enable A/D module
        ADCON1 = %10000000  ' Right justify, Vref = AVdd/AVss
        TRISA = %00001111     ' All inputs
        CMCON = %00100101   ' Single ended comparator inputs on RA1/RA2 C2OUT inverted
        ADCON0.2 = 1        ' Start A/D conversion
        While ADCON0.2 = 1  ' Wait for A/D conversion to complete
        WEND
        AD = (ADRESH << 8) | ADRESL
        Comp = COUT
        HSEROUT ["A/D in = ",DEC AD,13,10,"Comp out = " , DEC Comp,13,10]
        PAUSE 1000
        GOTO Main
    For this example I fixed RA2 at 2.5V through a 1K voltage divider. RA1 is
    the analog signal input to the comparator.
    RA0 is configured as an A/D input. The analog input signal is wired to both
    RA1 comparator & RA0 A/D input to display the analog value that flips C2OUT.
    Used a 5K pot for the analog signal in.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    jpeakall's Avatar
    jpeakall Guest
    Bruce,
    Once again thanks for the help. Got it all working a treat. Now to get my interrupt code all smoothed out...
    Jonathan
