Problem with PIC basic code *.bas
Results 1 to 9 of 9
    May 2005
    Red face Problem with PIC basic code *.bas
    I have try to make car robot and have problem with my code need all friend to help.
    Pls help to verify why did not work thank
    '* Name : IR_car3.BAS *
    '* Author : *
    '* Notice : Copyright (c) 2005 *
    '* : ALL Rights Reserved *
    '* Date : 10/3/2003 *
    '* Version : 1.0 *
    '* Notes : *
    @ DEVICE PIC16F84a, WDT_OFF,PWRT_ON, PROTECT_OFF
    TRISA = %00011111
    TRISB = %11111111
    IRpulse_length var word
    xx var Byte
    Command Var Byte
    Device Var Byte
    sw_l var PORTB.0
    sw_r var PORTB.1
    left var PORTA.0 'turn left
    right var PORTA.1 'turn right
    fwd var PORTA.2 'go
    bkd var PORTA.3 'back
    n var Byte
    n = 0
    'pause 150
    enable INTERRUPT
    START:
    LOW BKD
    HIGH FWD
    PAUSE 150
    If sw_l = 0 then
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    iF SW_r = 0 THEN
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    'Ir decoder
    PULSIN Portb.2,0,IRpulse_length(0)
    IF IRpulse_length(0) = 0 THEN start
    for xx =1 to 18
    pulsin Portb.2,0,IRpulse_length(xx)
    next xx
    disable INTERRUPT
    displaybits:
    if IRpulse_length(1) < 100 then
    Command.bit0 = 0
    Else
    Command.bit0 = 1
    if IRpulse_length(2) < 100 then
    Command.bit1 = 0
    Else
    Command.bit1 = 1
    if IRpulse_length(3) < 100 then
    Command.bit2 = 0
    Else
    Command.bit2 = 1
    if IRpulse_length(4) < 100 then
    Command.bit3 = 0
    Else
    Command.bit3 = 1
    if IRpulse_length(5) < 100 then
    Command.bit4 = 0
    Else
    Command.bit4 = 1
    if IRpulse_length(6) < 100 then
    Command.bit5 = 0
    Else
    Command.bit5 = 1
    if IRpulse_length(7) < 100 then
    Command.bit6 = 0
    Else
    Command.bit6 = 1
    Command.bit7 = 0
    Command = Command + 1
    If Command = 10 then
    Command = 0
    Endif
    if IRpulse_length(8) < 100 then
    Device.bit0 = 0
    Else
    Device.bit0 = 1
    if IRpulse_length(9) < 100 then
    Device.bit1 = 0
    Else
    Device.bit1 = 1
    if IRpulse_length(10) < 100 then
    Device.bit2 = 0
    Else
    Device.bit2 = 1
    if IRpulse_length(11) < 100 then
    Device.bit3 = 0
    Else
    Device.bit3 = 1
    'Device.bit1 = 0
    low portb.7
    'SEROUT Porta.3,sbaud,[#Device," - ",#Command,13,10]
    iF COMMAND = 13 THEN
    high left
    PAUSE 800
    RESUME
    ENABLE INTERRUPT
    'pause 100
    goto start
    Hi chai98a
    schematic and a few more details on what you want to do will be appreciated. Tell us what's working and what's not.
    May 2005
    Here is circuit of my project
    O.K. few things, there's no Pull-ups attach to yiur switches, but you can use the internal one... it can help
    OPTION_REG.7=0 ' turn on internal Pull-up.
    since you didn't declare any interrupt stuff you don't need to write Enable Interupt and Disable Interupt.
    Your TRISA definition is not right BUT High and Low do the job for you to correct it. I MEAN TRISA%00001111 will set PORTA<3:0> to input and PORTA<7:4> to output.
    what is the actual current needed by you motor? Is there any driver between your PIC and you motors? Are they DC type, Step, Servo?
    That's what i see as now
    May 2005
    Angry
    We use dc motor 3 vdc and driver with Transister (see circuit on attached)
    Let you mark new code sample for me too thank you. Plsssss.
    ssssssssssffffff BANG!
    I'm looking to your schematic and few things are wrong. Now all your transistors and/or few PIC i/o could be destroyed. by not using any resistor to your transistor base, you ask to PIC to drive as much current as I=E/R... aboute infinite. AND no clamping diode on Transistor while driving inductive load is for sure going to destroy your transistors really soon.
    can you, before changing everything, remove your transistor and use Leds, mini lamp, multimeter on PIC output to see if there's any signal that goes out.
    you can also use some H-Bridge driver to drive your Motor directly and make your design smaller on the final-Board.
    Do you also know the current needed by your Motor... not suppose to be really high. If you plan to use transistor i can do some schematic for you if you need or if you don't find any all over the net... wich i doubt!
    BUT if i need to drive a motor and i don't have any H-Bridge driver IC or they're current unsufficient, i'll prefer to use mosfet instead of bjt transistor due to the lowest voltage drop across and many more other reason but that's another story.
    May 2005
    Hi Mister_e
    Your right !!! on base of transister need to add R 1k .
    I will explan for my problem
    1. If we used code #1 (show as below) only the function of software will ok no problem
    if push sw_l ,sw_r motor backword and forword ...ok
    2. If we add code #2 (show as below) the function not ok
    a. the motor forword only not
    b. No repond if we push sw_l and sw_r
    I think may some error druing pic runing and may hung due to time over .....but i cannot find the problem
    ...I more exprien for pic (first study)
    thank you for advise
    My problem :
    we used microcode studio for careted code basic code and complier with PBP2.45 .
    #1
    TRISA = %00001111
    TRISB = %11111111
    xx var Byte
    Command Var Byte
    Device Var Byte
    sw_l var PORTB.0
    sw_r var PORTB.1
    left var PORTA.0
    right var PORTA.1
    fwd var PORTA.2
    bkd var PORTA.3
    n var Byte
    n = 0
    pause 150
    START:
    LOW BKD
    HIGH FWD
    PAUSE 150
    If sw_l = 0 then
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    iF SW_r = 0 THEN
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    goto start
    #2
    TRISA = %00001111
    TRISB = %11111111
    xx var Byte
    Command Var Byte
    Device Var Byte
    sw_l var PORTB.0
    sw_r var PORTB.1
    left var PORTA.0
    right var PORTA.1
    fwd var PORTA.2
    bkd var PORTA.3
    n var Byte
    n = 0
    pause 150
    START:
    LOW BKD
    HIGH FWD
    PAUSE 150
    If sw_l = 0 then
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    iF SW_r = 0 THEN
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    ' Ir decode
    high portb.7
    for xx =1 to 18
    next xx
    displaybits:
    Command.bit0 = 0
    Else
    Command.bit0 = 1
    Command.bit1 = 0
    Else
    Command.bit1 = 1
    Command.bit2 = 0
    Else
    Command.bit2 = 1
    Command.bit3 = 0
    Else
    Command.bit3 = 1
    Command.bit4 = 0
    Else
    Command.bit4 = 1
    Command.bit5 = 0
    Else
    Command.bit5 = 1
    Command.bit6 = 0
    Else
    Command.bit6 = 1
    Command.bit7 = 0
    Command = 0
    Endif
    Device.bit0 = 0
    Else
    Device.bit0 = 1
    Device.bit1 = 0
    Else
    Device.bit1 = 1
    Device.bit2 = 0
    Else
    Device.bit2 = 1
    Device.bit3 = 0
    Else
    Device.bit3 = 1
    'Device.bit1 = 0
    low portb.7
    high left
    PAUSE 800
    goto start
    Many times you use something like:
    IRpulse_length(0)
    I never see that kind of variable use so the question is...What should it do??? OR what do you want to do. I guess you want to store your results in an array so.. you'll have to declare your variable as an array
    something like
    IRpulse_length var word [20]
    and when you want to store/read from, use
    IRpulse_length[ArrayLocation]
    The reason why your switches don't work is because of those pulsin. look into your manual section 5.59 DEFINE PULSIN_MAX. This can help but not as efficient as you need to decode IR signal.
    In your case i'll prefer measuring incoming pulses by using Timer in an interrupt routine. Interrupt will be given by your IR receiver.. DUH!
    May 2005
    thank you for your advise
    i will try it again.
  1. Indexer not indexing...a basic PBP problem??
    By jellis00 in forum General
    Last Post: - 24th March 2009, 16:53
  2. I want to buy PIC BASIC PRO...
    By simransingh in forum General
    Last Post: - 30th October 2007, 17:13
  3. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 09:36
  4. Replies: 5
    Last Post: - 20th March 2006, 01:34
  5. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 04:07
