ssssssssssffffff BANG!
I'm looking to your schematic and few things are wrong. Now all your transistors and/or few PIC i/o could be destroyed. by not using any resistor to your transistor base, you ask to PIC to drive as much current as I=E/R... aboute infinite. AND no clamping diode on Transistor while driving inductive load is for sure going to destroy your transistors really soon.
can you, before changing everything, remove your transistor and use Leds, mini lamp, multimeter on PIC output to see if there's any signal that goes out.
you can also use some H-Bridge driver to drive your Motor directly and make your design smaller on the final-Board.
Do you also know the current needed by your Motor... not suppose to be really high. If you plan to use transistor i can do some schematic for you if you need or if you don't find any all over the net... wich i doubt!
BUT if i need to drive a motor and i don't have any H-Bridge driver IC or they're current unsufficient, i'll prefer to use mosfet instead of bjt transistor due to the lowest voltage drop across and many more other reason but that's another story.
