12F508 OPTION Register
Results 1 to 8 of 8
    Cambridge UK
    Default Re: 12F508 OPTION Register
    Looks like you need to resort to a bit of assembly to get to it.
    Now, I truly suck at assembly but if I were to try anything it would probably be something like:
    MOVLW 128   ; Put 128 in W (enable weel pullup).
    OPTION         ; Move content of W to OPTION
    Thanks Henrick, that assembly code helped me out with the 12f508. You have to TAB in once then write the code to remove errors.
    GPIO.2 and 3 work fine now. Cheers Nick
    Oct 2006
    Edmonton AB Canada
    Is this the same kind of process that might be used to get the TOCKI on Portc.5 to be used as a gpio? Any ideas?
    The datasheet says:
    On power-up, TOCKI functionality is enabled in the OPTION register and must be disabled to allow RC5 to be used as general purpose I/O.
    However, noplace does it state how to do that.
    Oct 2006
    Edmonton AB Canada
    p.s.
    That's on the 16f505 chip, not the 508
    Default Re: 16F505 OPTION Register
    The OPTION register is accessed the same as any other 16F. PBP translates it to an assembly OPTION command on 12-bit cores.
    To use RC5 as an output pin, use ...
    OPTION_REG.5 = 0
    Oct 2006
    Edmonton AB Canada
    Thanks Darrell, worked like a charm. Options are not so clear in the documentation.
  1. Auto Save option in editor
    By longpole001 in forum PBP Wish List
    Last Post: - 6th July 2012, 00:15
  2. Adding a Favorites Option to the Forum
    By rsocor01 in forum Forum Requests
    Last Post: - 18th July 2010, 18:09
  3. So many option but little understanding
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2010, 10:45
  4. Forum use option
    By F1CHF in forum Forum Requests
    Last Post: - 12th August 2006, 13:35
  5. 12F508 question...
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
