Shiftin/Shiftout
Results 1 to 2 of 2
    paul.mcallister's Avatar
    paul.mcallister Guest
    Default Shiftin/Shiftout
    Hi all,
    I wish to use an LTC1298 12 bit ACD converter. This device uses a serial interface. It is possible to tie the Dout and Din pins together and communicate via a single port for both input and output.
    So, here is my question. I want to use a PortB i/o line. I currently have PortB set up as all outputs with the pull up resisitors enabled. If I want to read the LTC1298 with a Shiftin, do I first have to reconfigure the one PortB line as an input prior to issuing this command, or will issueing the command be enough ? The Pic manual doesn't say and a search of the archives didn't turn up any clues. I am using PIC 18F876
    Thanks, Paul
    Usually PBP will set the pin itself. BUT if you feel safer to use INPUT PORTB.X before your Shiftin statement... give a go.
    Be carefull if you tie Do and DI... should isolate the DO pin with a diode with a pull down resistor.
  1. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
  2. Help! - Very strange results with ShiftIn/ShiftOut
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2005, 22:21
