Missing "TENS" digit
Results 1 to 5 of 5
    Jun 2011
    Default Missing "TENS" digit
    I made a 5 volt meter to monitor circuits. I have redesigned the circuit to monitor 12 volts. The circuit works fine, no issues there. My problem is in my program. The program doesn't show the "TENS" digit on the LCD Display. When I connect voltage to monitoring terminal, the LCD displays 2.05 volts instead of 12.05 volts. Could you look at my program and let me know where I need to modify it. Thanks, Greg
    Default Re: Missing "TENS" digit
    Please post your code, not a PDF.
    Jun 2011
    '@ DEVICE HS_OSC, WDT_OFF, BOD_OFF
    '***************************DEFINITIONS*********** ***************
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    define OSC 4
    TRISA = %00001011
    '**************************VARIABLES************** ****************
    x var word
    y var word
    z var word
    v var byte
    r var byte
    v2 var byte
    v3 var byte
    t var byte
    v4 var byte
    v5 var byte
    v6 var byte
    w var byte
    v7 var byte
    v8 var byte
    v9 var byte
    n var word
    m var byte
    v10 var byte
    v11 var byte
    v12 var byte
    'ADCON1 = 4 ' Set PortA 0, 1, 3 to A/D inputs
    ADCON1 = 2 ' Set PortA 0, 1, 2, 3, 4 to A/D inputs
    Low PORTE.2 ' LCD R/W line low (W)
    Pause 100 ' Wait for LCD to start
    Goto mainloop ' Skip subroutines
    '************************SUBROUTINES************** ************************
    getad: ' Subroutine to read A/D Converter
    PAUSEUS 50 ' Wait for A/D channel acquisition time
    ADCON0.2 = 1 ' Start conversion
    WHILE ADCON0.2 ' Wait for it to complete
    WEND
    getx: ' Subroutine to read x value
    ADCON0 = $41 ' Set A/D to Fosc/8, Channel 0, On
    Gosub getad
    x = ADRESH
    ' Calculations to convert x value to volts
    v = 5 * x / 255 * 4 ' Added * 4 to multiply reading back to 12 volts
    r = 5 * x // 255 * 4
    v2 = 100 * r / 255
    v3 = 100 * r // 255
    v3 = 10 * v3 / 255
    IF (v3 >= 5) THEN v2 = v2 + 1
    IF (v2 >= 100) THEN
    v = v + 1
    v2 = 0
    gety: ' Subroutine to read y value
    ADCON0 = $49 ' Set A/D to Fosc/8, Channel 1, On
    Gosub getad
    y = ADRESH
    v4 = 5 * y / 255 ' Calculations to convert y value to volts
    t = 5 * y // 255
    v5 = 100 * t / 255
    v6 = 100 * t // 255
    v6 = 10 * v6 / 255
    IF (v6 >= 5) THEN v5 = v5 + 1
    IF (v5 >= 100) THEN
    v4 = v4 + 1
    v5 = 0
    getz: ' Subroutine to read z value
    ADCON0 = $59 ' Set A/D to Fosc/8, Channel 3, On
    Gosub getad
    z = ADRESH
    v7 = 5 * z / 255 ' Calculations to convert y value to volts
    w = 5 * z // 255
    v8 = 100 * w / 255
    v9 = 100 * w // 255
    v9 = 10 * v9 / 255
    IF (v9 >= 5) THEN v8 = v8 + 1
    IF (v8 >= 100) THEN
    v7 = v7 + 1
    v8 = 0
    getn: ' Subroutine to read n value
    ADCON0 = $51 ' Set A/D to Fosc/8, Channel 2, On
    Gosub getad
    n = ADRESH
    v10 = 5 * n / 255 ' Calculations to convert y value to volts
    m = 5 * n // 255
    v11 = 100 * m / 255
    v12 = 100 * m // 255
    v12 = 10 * v12 / 255
    IF (v12 >= 5) THEN v11 = v11 + 1
    IF (v11 >= 100) THEN
    v10 = v10 + 1
    v11 = 0
    '**********************MAINLOOP******************* ********************
    mainloop:
    Gosub getx ' Get x value
    Gosub gety ' Get y value
    Gosub getz ' Get z value
    gosub getn ' Get n value
    Lcdout $fe, 1, DEC1 v, ".", DEC2 v2, " V1 " 'send to LCD
    lcdout $fe, $14, dec1 v4, ".", dec2 v5, " V2" 'send to LCD
    lcdout $fe, $c0, dec1 v7, ".", dec2 v8, " V3 " 'send to LCD
    lcdout $fe, $14, dec1 v10, ".", dec2 v11, " V4" 'send to LCD
    Pause 100 ' Do it about 10 times a second
    if x<125 and y>125 and z>125 and n>125 then high PortD.1 '125 = 2.5V
    if y<125 and x>125 and z>125 and n>125 then high PortD.0
    if z<125 and x>125 and y>125 and n>125 then high PortD.2
    if n<125 and x>125 and y>125 and z>125 then high PortD.3
    Goto mainloop ' Do it forever
    You are telling the lcdout command to send only 2 individual digits."DEC1 v, ".", DEC2 v2" I see nowhere that you are sending the full value. Also the variables are sized as bytes. The maximum value you can have is 255.
    EN82fn
    Oct 2011
    At a quick glance I would suggest changing
    Lcdout $fe, 1, DEC1 v, ".", DEC2 v2 to
    Lcdout $fe, 1, DEC2 v, and the same for the 3 following lines
    Phil
  1. Replies: 3
    Last Post: - 15th October 2012, 09:06
  2. Replies: 8
    Last Post: - 3rd March 2011, 23:20
  3. Replies: 24
    Last Post: - 7th November 2008, 05:41
  4. Replies: 2
    Last Post: - 22nd January 2008, 15:25
  5. Replies: 1
    Last Post: - 16th February 2005, 21:05
