Help with 18b20 Stuck with busy bit
Results 1 to 5 of 5
    Oct 2009
    Utah, USA
    Default Re: Help with 18b20 Stuck with busy bit
    you might take a look at this example... (located in the wiki section under projects/temperature)
    http://www.picbasic.co.uk/forum/cont...r-nine-of-them
    you can also search on "ds18b20" for other examples.
    I would suggest you go through your code and add lots of comments to help you trouble shoot and for others to follow what you are trying to do.
    Dwight
    Apr 2012
    Ptolemaida
    Ty Heckler for the reply, but the link that you gave me my friend doesn't work. Stuck in loading... I deleted comments for posting on site i have done them properly :P :P
    My problem is the presence pulse, i can't understand how it works even i have read the datasheet hundrend of times.
    I do low for initialise, i do get a low and going for the converting procedure. But i never get the busy bit back, even i did it with 2 diffrent ways.
    I suspect that the problem is the presence pulse but i dont know how to check it and that's why i came with a post (i also have read a couple of other threads but still no luck) .
    Dec 2008
    Ploiesti, ROMANIA
    Take a look here, for a verry good example : http://www.rentron.com/PicBasic/one-wire3.htm
    Apr 2012
    Ptolemaida
    I think i found out the problem.... I haven't disabled the A/D inputs nor the Comparators and OPTION_REG . I'll try it out when i have time and ill let you know !!!
  1. Bit order for HSEROUT[A]
    Last Post: - 2nd October 2012, 04:47
  2. ds 18b20 circuit.
    By johnyp in forum mel PIC BASIC Pro
    Last Post: - 6th March 2010, 18:40
  3. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 14:51
  4. BUSY line technique
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2005, 13:33
