Sure, here is the PicBasic listing for a DEVICE, for a COORDINATOR just comment the device line (line 219) and uncomment line 212 in the initialization routine.
One must be a coordinator, all others should be devices.
'* Name : MRFshort.BAS *
'* Author : SCUMARI Tec *
'* Notice : Copyright (c) 2013 SCUMARI Group *
'* : All Rights Reserved *
'* Date : 3-6-2013 *
'* Version : 1.0 *
'* Notes : PIC18LF13K50 controller for the MRF24J40MA module *
'* : This is standard software for both sender and receiver. *
'* : Both modules start in receive mode.When the button is pressed,*
'* : a byte is randomized and send over. Both receiver and sender *
'* : displays the value of 1 byte on a LED bar. *
' PIC18LF13K50
' ___ ___
' VDD O|1 - 20|O VSS
' RA5 OSC1 OSCIN O|2 19|O RA0 + PGD
' RA4 AN3 OSC2 CLKOUT O|3 18|O RA1 D- PGC
' RA3 MCLR VPP O|4 17|O VUSB
' RC5 CCP P1A T0CKI O|5 16|O RC0 AN4 C12IN+ INT0 VREF+
' RC4 P1B C12OUT SRQ O|6 15|O RC1 AN5 C12IN1- INT1 VREF-
' RC3 AN7 P1C C12IN3- PGM O|7 14|O RC2 AN6 P1D C12IN2- CVREF INT2
' RC6 AN8 SS T13CKI T1OSCI O|8 13|O RB4 AN10 SDI SDA
' RC7 AN9 SDO T1OSCO O|9 12|O RB5 AN11 RX DT
' RB7 TX CK O|10 11|O RB6 SCK SCL
'18F13K50
@ __CONFIG _CONFIG1L, 000h
@ __CONFIG _CONFIG1H, 018h
@ __CONFIG _CONFIG2L, 000h
@ __CONFIG _CONFIG2H, 000h
@ __CONFIG _CONFIG3H, 080h ;080h is MCLRE
@ __CONFIG _CONFIG4L, 000h
@ __CONFIG _CONFIG5L, 003h
@ __CONFIG _CONFIG5H, 0C0h
@ __CONFIG _CONFIG6L, 003h
@ __CONFIG _CONFIG6H, 0E0h
@ __CONFIG _CONFIG7L, 003h
@ __CONFIG _CONFIG7H, 040h
INCLUDE "modedefs.bas"
include "MRF24J40def.inc"
DEFINE OSC 16
OSCCON = %01100010 '4550 op $FE / K50 op 118 / 689 op 112
OSCTUNE = $1F '4550 op $0F / K50 op 31 / 689 op 15
ADCON0 = 0
ANSEL = 0
ANSELH = 0
UCON = 0
IOCA = 3
IOCB = 0
INTCON = 0
PORTA = 0
TRISA = %00111111
PORTB = 0
TRISB = %00000000
PORTC = 0
TRISC = 0
intx VAR PORTA.4
res VAR PORTB.4
sdi VAR PORTB.5
sck VAR PORTB.6
sdo VAR PORTA.5
cs VAR PORTB.7
'wake vAR PORTB.7
butt var PORTA.0
addr var byte
addrm var word
addrl VAR addrm.byte0
addrh VAR addrm.byte1
temp VAR word
tmp VAR BYTE
indat VAR BYTE
outdat VAR BYTE
i VAR BYTE
channel var byte
txRadioBuffer var byte[128]
rxRadioBuffer var byte[128]
txHeader var Byte[11]
txDestination VAR word
txPayLoad VAR BYTE
HeaderLength VAR BYTE
FrameLength VAR BYTE
FrameControl VAR word
IEEEseqNumber VAR BYTE
wcnt VAR BYTE
bRetVal VAR BYTE
IntStatus var Byte
fifo var word
sdata var word
RadioState var byte
' '******** Setup interrupt 18F4520**********
' GIE var INTCON.7 'global interrupt enable
' INT0IE var INTCON.4 'enable int0, portb.0
' INT0IF var INTCON.1 'interrupt flag
' INTEDG0 var INTCON2.6 'SLPCON0.1 'Interrupt Edge Select
' 'Symbol INT0IP con INTCON3.7
' IPEN var RCON.7
' GIE = 0
' INT0IE = 0
TX_BUFFER_SIZE con 127
RX_BUFFER_SIZE con 127
'Times
tlong con 50
tmid con 25
tshort con 15
'FrameControl = %0010001000100110
FrameControl = %1001100001000001
'index Value
' frametype 3 bits 001
' securityEnabled 1 0
' framepending 1 0
' ackRequest 1 0
' intraPAN 1 1
' don't care 1 0
' don't care 2 00
' destAddressMode 2 10 0x02
' frameVersion 2 01 datasheet says this is reserved
' sourceAddressMode 2 10
cs = 1
res = 1
PORTC = 129
pause 50
PORTC = 66
pause 50
PORTC = 36
pause 50
PORTC = 24
pause 50
PORTC = 24
pause 50
PORTC = 36
pause 50
PORTC = 66
pause 50
PORTC = 129
pause 50
PORTC = 0
'IntFlag = 0 'remember to remove this
gosub initialize
addr = INTSTAT: gosub DataRd
'PORTC = indat
'pause 100
if indat.3 = 1 then gosub receive
'if intx = 0 then gosub Receive
If butt = 0 Then gosub Send
'pause 250
GoTo main
'>>>>>> SUBROUTINES <<<<<<<<<<<<<<<<<<
Initialize:
res = 0
pause 10
res = 1
pause 10
'Example steps to initialize the MRF24J40:
'1. SOFTRST (0x2A) = 0x07 – Perform a software Reset. The bits will be automatically cleared to ‘0’ by hardware.
'2. PACON2 (0x18) = 0x98 – Initialize FIFOEN = 1 and TXONTS = 0x6.
'3. TXSTBL (0x2E) = 0x95 – Initialize RFSTBL = 0x9.
'4. RFCON1 (0x201) = 0x01 – Initialize VCOOPT = 0x01.
'5. RFCON2 (0x202) = 0x80 – Enable PLL (PLLEN = 1).
'6. RFCON6 (0x206) = 0x90 – Initialize TXFIL = 1 and 20MRECVR = 1.
'7. RFCON7 (0x207) = 0x80 – Initialize SLPCLKSEL = 0x2 (100 kHz Internal oscillator).
'8. RFCON8 (0x208) = 0x10 – Initialize RFVCO = 1.
'9. SLPCON1 (0x220) = 0x21 – Initialize CLKOUTEN = 1 and SLPCLKDIV = 0x01.
addr = SOFTRST: outdat = 7: gosub DataWr
init2:
Indat = 0
addr = SOFTRST: gosub DataRd
if indat <> 0 then goto init2
addr = PACON2: outdat = $98: gosub DataWr
addr = TXSTBL: outdat = $95: gosub DataWr
addrm = RFCON1: outdat = $01: gosub LDataWr
addrm = RFCON2: outdat = $80: gosub LDataWr
addrm = RFCON6: outdat = $90: gosub LDataWr
addrm = RFCON7: outdat = $80: gosub LDataWr
addrm = RFCON8: outdat = $10: gosub LDataWr
addrm = SLPCON1: outdat = $21: gosub LDataWr
'** Device or Coordinator ************************************************** ****
'3.8.2.1 Configuring Nonbeacon-Enabled PAN Coordinator
'The following steps configure the MRF24J40 as a coordinator in a nonbeacon-enabled network:
'1. Set the PANCOORD (RXMCR 0x00<3>) bit = 1 to configure as the PAN coordinator.
'2. Clear the SLOTTED (TXMCR 0x11<5>) bit = 0 to configure Unslotted CSMA-CA mode.
'3. Configure BO (ORDER 0x10<7:4>) value = 0xF.
'4. Configure SO (ORDER 0x10<3:0>) value = 0xF.
'addr = TXMCR: gosub DataRd
'outdat = indat: indat.5 = 0 'bit 5 = 0
'addr = TXMCR: gosub DataWr
' addr = RXMCR: outdat = 8: gosub DataWr 'PROMI & COORD To make it a Coordinator
'addr = ORDER: outdat = $FF: gosub DataWr
'3.8.2.1 Configuring Nonbeacon-Enabled device
'1. Set the PANCOORD (RXMCR 0x00<3>) bit = 0 to configure as the device.
addr = RXMCR: outdat = 0: gosub DataWr 'PROMI To make it a Device
'(see Section 3.8 “Beacon-Enabled and Nonbeacon-Enabled Networks”):
'10. BBREG2 (0x3A) = 0x80 – Set CCA mode to ED.
'11. RSSITHCCA (0x3F) = 0x60 – Set CCA ED threshold.
'12. BBREG6 (0x3E) = 0x40 – Set appended RSSI value to RXFIFO.
'13. Enable interrupts – See Section 3.3 “Interrupts”.
'14. Set channel – See Section 3.4 “Channel Selection”.
'15. RFCTL (0x36) = 0x04 – Reset RF state machine.
'16. RFCTL (0x36) = 0x00.
'17. Delay at least 192 ms.
addr = BBREG2: outdat = $80: gosub DataWr
addr = CCAEDTH: outdat = $60: gosub DataWr
addr = BBREG6: outdat = $60: gosub DataWr
addr = INTCON: outdat = 8: gosub DataWr 'RXIE
addrm = RFCON0: outdat = $82: gosub LDataWr 'Channel 19
addr = RFCTL: outdat = 4: gosub DataWr
'pauseUS 10
addr = RFCTL: outdat = 0: gosub DataWr
addr = PANIDL: outdat = $01: gosub DataWr
addr = PANIDH: outdat = $02: gosub DataWr
addr = SADRL: outdat = $CD: gosub DataWr
addr = SADRH: outdat = $AB: gosub DataWr
pauseUS 10 'as per datasheet wait at least 192uS
For i = 0 To TX_BUFFER_SIZE
txRadioBuffer[i] = i '0x00 put in some data
Next
For i = 0 To RX_BUFFER_SIZE
rxRadioBuffer[i] = 0
Next
addr = RXFLUSH: outdat = 1: gosub DataWr
'***** RECEIVING ************************************************** ***************
Receive:
'Indat = 0
'addr = INTSTAT: gosub DataRd 'what caused the interrupt
addr = BBREG1: outdat = 4: gosub DataWr 'RXDECINV = 1
bRetVal = 0
addrm = RX_FIFO: gosub LDataRd
rxRadioBuffer[0] = indat
For i = 1 To (rxRadioBuffer[0] + 2)
addrm = (RX_FIFO + i): gosub LDataRd
rxRadioBuffer[i] = indat
Next
PORTC = rxRadioBuffer[10]
addr = BBREG1: outdat = 0: gosub DataWr 'RXDECINV = 0
pause 250
'***** SENDING ************************************************** ***************
Send:
For i = 0 To 127 'make sure there is valid data in array
Next
txDestination = $FFFF ' Set the destination address
txPayLoad = 16 ' set amount of data to xmitt from array(payload)
're-write first 11 bytes with hdrLen, frm Len and Header
'// Compute and send header and frame length
HeaderLength = 9 '(index 2 to 10, 9 bytes)
FrameLength = HeaderLength + txPayLoad '9 (0-8)+ 16 (0-15) = 25
'address 0-1 '2 bytes
txHeader[0] = HeaderLength
txHeader[1] = FrameLength
'address 2-10 '8 bytes
txHeader[2] = FrameControl.LowByte 'framecontrol[0] 0x26
txHeader[3] = FrameControl.HighByte 'framecontrol[1] 0x22
txHeader[4] = IEEEseqNumber 'IEEEseqNumber++
txHeader[5] = $01 'myPANID[0]
txHeader[6] = $02 'myPANID[1]
txHeader[7] = txDestination.LowByte 'networkTX.dest & 0x00FF
txHeader[8] = txDestination.HighByte 'networkTX.dest >> 8
txHeader[9] = $cd 'myShortAddress[0]
txHeader[10] = $ab 'myShortAddress[1]
IEEEseqNumber = IEEEseqNumber + 1
fifo = 0
For i = 0 To HeaderLength + 1 'header & hdr len & frame len =11
addrm = fifo: outdat = txHeader[i]: gosub LDataWr
fifo = fifo + 1
Next
random temp
PORTC = temp
For i = 0 To txPayLoad-1 'FrameLength +1
addrm = fifo: outdat = temp: gosub LDataWr
fifo = fifo + 1
Next
addr = TXNCON: outdat = 1: gosub DataWr
pause 250
DataWr:
cs = 0
sdi = 0
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
for tmp = 0 to 5
sdi = addr.5
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
sdi = 1
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
'Read data
indat = 0
for tmp = 0 to 7
sdi = outdat.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
outdat = outdat << 1
pauseus tmid
next tmp
cs = 1
DataRd:
indat = 0
cs = 0
sdi = 0
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
for tmp = 0 to 5
sdi = addr.5
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
sdi = 0
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
indat = 0
for tmp = 0 to 7
indat = indat << 1
sck = 1
pauseus tmid
indat = indat + sdo
sck = 0
pauseus tmid
next tmp
cs = 1
LDataWr:
cs = 0
sdi = 1
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
for tmp = 0 to 9
sdi = addrm.9
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addrm = addrm << 1
pauseus tmid
next tmp
sdi = 1
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
indat = 0
for tmp = 0 to 7
sdi = outdat.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
next tmp
cs = 1
LDataRd:
indat = 0
cs = 0
sdi = 1
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
for tmp = 0 to 9
sdi = addrm.9
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addrm = addrm << 1
pauseus tmid
next tmp
sdi = 0
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
sck = 1
pauseus tmid
sck = 0
pauseus tmid
indat = 0
for tmp = 0 to 7
indat = indat << 1
sck = 1
pauseus tmid
indat = indat + sdo
sck = 0
pauseus tmid
next tmp
cs = 1
Below is the MFR24J40def.inc include file
'' MRF24J40 Definitions
'' This file is similar to the original MRF24J40.h provided by Microchip.
'' The register names have been modified to reflect the names used in the
'' documentation (DS39776B). Also the Short Address Register definitions
'' are NOT pre-formatted for SPI transmission to the transceiver. In other
'' words, they are just addresses. This is, in my opinion, much easier to
'' comprehend.
'' Also included in this file are individual register definitions to be added
'' as needed. They are each defined as a union of an symbol byte and an
'' anonymous structure defining the individual fields. This eliminates the
'' tedious task of including a ".bits" member qualifier with each reference to
'' a member field. This is compatible with the MPLAB C18 compiler; other
'' compilers...maybe not so much.
Symbol BEACON_FRAME = 0
Symbol DATA_FRAME = 1
Symbol ACK_FRAME = 2
Symbol MAC_CMD_FRAME = 3
Symbol NO_ADDR = 0
Symbol ADDR_16 = 2
Symbol ADDR_64 = 3
'' Define FIFO addresses
Symbol NORMAL_TX_FIFO = $0
Symbol BEACON_TX_FIFO = $80
Symbol GTS1_TX_FIFO = $100
Symbol GTS2_TX_FIFO = $180
Symbol RX_FIFO = $300
Symbol SECURITY_FIFO = $280
'//Long Address Control Registers
Symbol RFCON0 = $200
Symbol RFCON1 = $201
Symbol RFCON2 = $202
Symbol RFCON3 = $203
Symbol RFCON4 = $204
Symbol RFCON5 = $205
Symbol RFCON6 = $206
Symbol RFCON7 = $207
Symbol RFCON8 = $208
Symbol SLPCAL1 = $209
Symbol SLPCAL2 = $20a
Symbol SLPCAL3 = $20b
Symbol SFCNTRH = $20c ' Now reserved?
Symbol SFCNTRM = $20d ' Now reserved?
Symbol SFCNTRL = $20e ' Now reserved?
Symbol RFSTATE = $20f
Symbol RSSI = $210
Symbol SLPCON0 = $211
Symbol SRCADRMODE = $212 ' Now reserved?
Symbol SRCADDR0 = $213 ' Now reserved?
Symbol SRCADDR1 = $214 ' Now reserved?
Symbol SRCADDR2 = $215 ' Now reserved?
Symbol SRCADDR3 = $216 ' Now reserved?
Symbol SRCADDR4 = $217 ' Now reserved?
Symbol SRCADDR5 = $218 ' Now reserved?
Symbol SRCADDR6 = $219 ' Now reserved?
Symbol SRCADDR7 = $21a ' Now reserved?
Symbol RXFRAMESTATE = $21b ' Now reserved?
Symbol SECSTATUS = $21c ' Now reserved?
Symbol STCCMP = $21d ' Now reserved?
Symbol HLEN = $21e ' Now reserved?
Symbol FLEN = $21f ' Now reserved?
Symbol SLPCON1 = $220
Symbol WAKETIMEL = $222
Symbol WAKETIMEH = $223
Symbol REMCNTL = $224
Symbol REMCNTH = $225
Symbol MAINCNT0 = $226
Symbol MAINCNT1 = $227
Symbol MAINCNT2 = $228
Symbol MAINCNT3 = $229
Symbol RFMANUALCTRLEN = $22a ' Now reserved?
Symbol RFMANUALCTRL = $22b ' Now reserved?
'symbol RFRXCTRL RFMANUALCTRL
Symbol TxDACMANUALCTRL = $22c ' Now reserved?
Symbol RFMANUALCTRL2 = $22d ' Now reserved?
Symbol TESTRSSI = $22e ' Now reserved?
Symbol TESTMODE = $22f
Symbol ASSOEADR0 = $230
Symbol ASSOEADR1 = $231
Symbol ASSOEADR2 = $232
Symbol ASSOEADR3 = $233
Symbol ASSOEADR4 = $234
Symbol ASSOEADR5 = $235
Symbol ASSOEADR6 = $236
Symbol ASSOEADR7 = $237
Symbol ASSOSADR0 = $238
Symbol ASSOSADR1 = $239
Symbol UPNONCE0 = $240
Symbol UPNONCE1 = $241
Symbol UPNONCE2 = $242
Symbol UPNONCE3 = $243
Symbol UPNONCE4 = $244
Symbol UPNONCE5 = $245
Symbol UPNONCE6 = $246
Symbol UPNONCE7 = $247
Symbol UPNONCE8 = $248
Symbol UPNONCE9 = $249
Symbol UPNONCE10 = $24A
Symbol UPNONCE11 = $24B
Symbol UPNONCE12 = $24C
'' Short Address Register definitions:
Symbol RXMCR = $0
Symbol PANIDL = $01
Symbol PANIDH = $02
Symbol SADRL = $03
Symbol SADRH = $04
Symbol EADR0 = $05
Symbol EADR1 = $06
Symbol EADR2 = $07
Symbol EADR3 = $08
Symbol EADR4 = $09
Symbol EADR5 = $0A
Symbol EADR6 = $0B
Symbol EADR7 = $0C
Symbol RXFLUSH = $0D
Symbol TXSTATE0 = $0E
Symbol TXSTATE1 = $0F
Symbol ORDER = $10
Symbol TXMCR = $11
Symbol ACKTMOUT = $12
Symbol ESLOTG1 = $13
Symbol SYMTICKL = $14
Symbol SYMTICKH = $15
Symbol PACON0 = $16
Symbol PACON1 = $17
Symbol PACON2 = $18
Symbol CSMACR = $19
Symbol TXBCON0 = $1A
Symbol TXNCON = $1B
Symbol TXG1CON = $1C
Symbol TXG2CON = $1D
Symbol ESLOTG23 = $1E
Symbol ESLOTG45 = $1F
Symbol ESLOTG67 = $20
Symbol TXPEND = $21
Symbol WAKECON = $22
Symbol FRMOFFSET = $23
Symbol TXSTAT = $24
Symbol TXBCON1 = $25
Symbol GATECLK = $26
Symbol TXTIME = $27
Symbol HSYMTMRL = $28
Symbol HSYMTMRH = $29
Symbol SOFTRST = $2A
Symbol BISTCR = $2B
Symbol SECCON0 = $2C
Symbol SECCON1 = $2D
Symbol TXSTBL = $2E
Symbol SECISR = $2F
Symbol RXSR = $30
Symbol INTSTAT = $31
Symbol INTCONT = $32
Symbol GPIO = $33
Symbol TRISGPIO = $34
Symbol SLPACK = $35
Symbol RFCTL = $36
Symbol SECCR2 = $37
Symbol BBREG0 = $38
Symbol BBREG1 = $39
Symbol BBREG2 = $3A
Symbol BBREG3 = $3B
Symbol BBREG4 = $3C
Symbol BBREG5 = $3D
Symbol BBREG6 = $3E
Symbol CCAEDTH = $3F
'' TXSTAT: TX MAC STATUS REGISTER (ADDRESS: 0x24)
'symbol TXNSTAT = ' TX Normal FIFO Release Status bit
'symbol TXG1STAT:1; ' TX GTS1 FIFO Release Status bit
'symbol TXG2STAT:1; ' TX GTS2 FIFO Release Status bit
'symbol TXG1FNT:1; ' TX GTS1 FIFO transmission failed (timeout
'symbol TXG2FNT:1; ' TX GTS2 FIFO transmission failed (timeout
'symbol CCAFAIL:1; ' Clear Channel Assessment Status of last transmit
'symbol TXNRETRY:2; ' TX Normal FIFO Retry Times
'' INTSTAT: INTERRUPT STATUS REGISTER (ADDRESS: 0x31
'symbol TXNIF = ISRSTS.0 ' TX Normal FIFO Release Interrupt bit
'symbol TXG1IF = ISRSTS.1 ' TX GTS1 FIFO Transmission Interrupt bit
'symbol TXG2IF = ISRSTS.2 ' TX GTS2 FIFO Transmission Interrupt bit
'symbol RXIF = ISRSTS.3 ' RX FIFO Reception Interrupt bit
'symbol SECIF = ISRSTS.4 ' Security Key Request Interrupt bit
'symbol HSYMTMRIF = ISRSTS.5 ' Half Symbol Timer Interrupt bit
'symbol WAKEIF = ISRSTS.6 ' Wake-up Alert Interrupt bit
'symbol SLPIF = ISRSTS.7 ' Sleep Alert Interrupt bit
'' INTCON: INTERRUPT CONTROL REGISTER (ADDRESS: 0x32
'symbol TXNIE:1; ' TX Normal FIFO Transmission Interrupt Enable bit
'symbol TXG1IE:1; ' TX GTS1 FIFO Transmission Interrupt Enable bit
'symbol TXG2IE:1; ' TX GTS2 FIFO Transmission Interrupt Enable bit
'symbol RXIE:1; ' RX FIFO Reception Interrupt Enable bit
'symbol SECIE:1; ' Security Key Request Interrupt Enable bit
'symbol HSYMTMRIE:1; ' Half Symbol Timer Interrupt Enable bit
'symbol WAKEIE:1; ' Wake-up Alert Interrupt Enable bit
'symbol SLPIE:1; ' Sleep Alert Interrupt Enable bit
Have fun with it
