MRF24J40MA with a PIC18LF13K50
Results 1 to 12 of 12
    scumari's Avatar
    scumari Guest
    Default MRF24J40MA with a PIC18LF13K50
    Hi
    Trying to create a universal code for a MRF24J40MA with a PIC18LF13K50 controller in MELabs PICBASIC PRO 2.6, that should work as a receiver aswell as a transmitter, I encountered a few problems.
    The code I use and the drawing can be downloaded here.
    Pressing the send button should send one randomized byte in the air. The receiving unit shout receive it and copy it to the LEDS on the C-port.
    The point is, I can't get it to work at all!
    Did anyone have it working in PICBASIC?
    Thanx in advance
    Default Re: MRF24J40MA with a PIC18LF13K50
    It's been done in Basic.
    See MRF24J40MA RF Code working.
    Warning other compiler.
    I thought I saw it also on the WiKi but can't find it now.
    Norm
    scumari's Avatar
    scumari Guest
    Translated that one for PICBASIC, did't work at all!
    Thanx anyway
    Maybe if you show you translated code someone might be able to help. And please do not expect folks to download and open a ZIP, just post the info.
    Quote Originally Posted by scumari View Post
    Thanx anyway
    It does work, I have it working but not in PicBasicPro.
    Norm
    scumari's Avatar
    scumari Guest
    It is a ZIP because it exsists of three files, the basic source, an inc file and a pdf with the drawing of the connections.
    If you are scared of downloading ZIP files, a good virus scanner should be more than sufficient to be save.
    It's downloadable from my own site and should be save..............
    The Proton listing uses a different microcontroller and gives me SPI.inc errors while compiling from the start! Unusable for me.
    At first I used an old proton source and translated it directly to PICBASIC PRO. It compiled but was not complete.
    Then I recreated the Initializing, transmitting and receiving code with the MRF pdf file as guide.
    Now I'm stuck.
    scumari's Avatar
    scumari Guest
    For those still affraid of ZIP files:
    '* Name : MRF.BAS *
    '* Author : SCUMARI Tec *
    '* Notice : *
    '* : All Rights Reserved *
    '* Date : 7-6-2012 *
    '* Version : 1.0 *
    '* Notes : *
    ' PIC18LF13K50
    ' ___ ___
    ' VDD O|1 - 20|O VSS
    ' RA5 OSC1 OSCIN O|2 19|O RA0 + PGD
    ' RA4 AN3 OSC2 CLKOUT O|3 18|O RA1 D- PGC
    ' RA3 MCLR VPP O|4 17|O VUSB
    ' RC5 CCP P1A T0CKI O|5 16|O RC0 AN4 C12IN+ INT0 VREF+
    ' RC4 P1B C12OUT SRQ O|6 15|O RC1 AN5 C12IN1- INT1 VREF-
    ' RC3 AN7 P1C C12IN3- PGM O|7 14|O RC2 AN6 P1D C12IN2- CVREF INT2
    ' RC6 AN8 SS T13CKI T1OSCI O|8 13|O RB4 AN10 SDI SDA
    ' RC7 AN9 SDO T1OSCO O|9 12|O RB5 AN11 RX DT
    ' RB7 TX CK O|10 11|O RB6 SCK SCL
    '18F14K50
    @ __CONFIG _CONFIG1L, 000h
    @ __CONFIG _CONFIG1H, 018h
    @ __CONFIG _CONFIG2L, 000h
    @ __CONFIG _CONFIG2H, 000h
    @ __CONFIG _CONFIG3H, 080h ;080h is MCLRE
    @ __CONFIG _CONFIG4L, 000h
    @ __CONFIG _CONFIG5L, 003h
    @ __CONFIG _CONFIG5H, 0C0h
    @ __CONFIG _CONFIG6L, 003h
    @ __CONFIG _CONFIG6H, 0E0h
    @ __CONFIG _CONFIG7L, 003h
    @ __CONFIG _CONFIG7H, 040h
    'INCLUDE "modedefs.bas"
    include "MRF24J40def.inc"
    DEFINE OSC 16
    OSCCON = %01100010 '4550 op $FE / K50 op 118 / 689 op 112
    OSCTUNE = $1F '4550 op $0F / K50 op 31 / 689 op 15
    ADCON0 = 0
    ANSEL = 0
    ANSELH = 0
    UCON = 0
    IOCA = 3
    IOCB = 0
    INTCON = 0
    PORTA = 0
    TRISA = %00001111
    PORTB = 0
    TRISB = %01000000
    PORTC = 0
    TRISC = 0
    intx VAR PORTA.1
    res VAR PORTA.4
    cs VAR PORTA.5
    sdi VAR PORTB.4
    sck VAR PORTB.5
    sdo VAR PORTB.6
    wake vAR PORTB.7
    butt var PORTA.0
    addr var byte
    addrm var word
    temp VAR word
    tmp VAR BYTE
    indat VAR BYTE
    outdat VAR BYTE
    i VAR BYTE
    channel var byte
    txRadioBuffer var byte[128]
    rxRadioBuffer var byte[128]
    txDestination VAR word
    txPayLoad VAR BYTE
    HeaderLength VAR BYTE
    FrameLength VAR BYTE
    FrameControl VAR word
    IEEEseqNumber VAR BYTE
    wcnt VAR BYTE
    bRetVal VAR BYTE
    IntStatus var Byte
    TX_BUFFER_SIZE con 128
    RX_BUFFER_SIZE con 128
    'Times
    tlong con 100
    tmid con 50
    tshort con 25
    cs = 1
    res = 1
    PORTC = 129
    pause 50
    PORTC = 66
    pause 50
    PORTC = 36
    pause 50
    PORTC = 24
    pause 50
    PORTC = 24
    pause 50
    PORTC = 36
    pause 50
    PORTC = 66
    pause 50
    PORTC = 129
    pause 50
    PORTC = 0
    'IntFlag = 0 'remember to remove this
    gosub initialize
    'ON INTERRUPT GOTO ReceiveData
    'disable
    'INTCON = %10010000 ' Enable RB0 interrupt
    'On_Hardware_Interrupt GoTo Radio_ISR
    ' GIE = 0 'disable global int
    ' IPEN = 0 'disable high pri interupts
    ' INT2IP =0 'disable int2 high pri not using priorty
    ' INT2IE = 0 'disable int2 portb.2
    ' INTEDG2 = 0 'rising
    enable
    if butt = 0 then
    'PORTC = 255
    GoSub SendMessage
    'goto main
    'disable
    ReceiveData:
    if intx = 1 then
    'DISABLE ' Disable interrupts in handler
    'PORTC = 255
    gosub RecMessage
    'RESUME ' Return to main program
    'ENABLE ' Enable interrupts after handler
    Initialize:
    res = 0
    pause 10
    res = 1
    pause 10
    'Example steps to initialize the MRF24J40:
    '1. SOFTRST (0x2A) = 0x07 – Perform a software Reset. The bits will be automatically cleared to ‘0’ by hardware.
    '2. PACON2 (0x18) = 0x98 – Initialize FIFOEN = 1 and TXONTS = 0x6.
    '3. TXSTBL (0x2E) = 0x95 – Initialize RFSTBL = 0x9.
    '4. RFCON1 (0x201) = 0x01 – Initialize VCOOPT = 0x01.
    '5. RFCON2 (0x202) = 0x80 – Enable PLL (PLLEN = 1).
    '6. RFCON6 (0x206) = 0x90 – Initialize TXFIL = 1 and 20MRECVR = 1.
    '7. RFCON7 (0x207) = 0x80 – Initialize SLPCLKSEL = 0x2 (100 kHz Internal oscillator).
    '8. RFCON8 (0x208) = 0x10 – Initialize RFVCO = 1.
    '9. SLPCON1 (0x220) = 0x21 – Initialize CLKOUTEN = 1 and SLPCLKDIV = 0x01.
    addr = SOFTRST: gosub ShAddr: outdat = 7: gosub DataWr
    addr = PACON2: gosub ShAddr: outdat = $98: gosub DataWr
    addr = TXSTBL: gosub ShAddr: outdat = $95: gosub DataWr
    addrm = RFCON1: gosub LoAddr: outdat = $01: gosub LDataWr
    addrm = RFCON2: gosub LoAddr: outdat = $80: gosub LDataWr
    addrm = RFCON6: gosub LoAddr: outdat = $90: gosub LDataWr
    addrm = RFCON7: gosub LoAddr: outdat = $80: gosub LDataWr
    addrm = RFCON8: gosub LoAddr: outdat = $10: gosub LDataWr
    addrm = SLPCON1: gosub LoAddr: outdat = $21: gosub LDataWr
    '3.8.2.1 Configuring Nonbeacon-Enabled PAN Coordinator
    'The following steps configure the MRF24J40 as a coordinator in a nonbeacon-enabled network:
    '1. Set the PANCOORD (RXMCR 0x00<3>) bit = 1 to configure as the PAN coordinator.
    '2. Clear the SLOTTED (TXMCR 0x11<5>) bit = 0 to configure Unslotted CSMA-CA mode.
    '3. Configure BO (ORDER 0x10<7:4>) value = 0xF.
    '4. Configure SO (ORDER 0x10<3:0>) value = 0xF.
    addr = RXMCR: gosub ShAddr: gosub DataRd
    outdat = indat or 8 'bit 3 = 1
    addr = RXMCR: gosub ShAddr: gosub DataWr
    addr = TXMCR: gosub ShAddr: gosub DataRd
    outdat = indat and 223 'bit 5 = 0
    addr = TXMCR: gosub ShAddr: gosub DataWr
    '>>> 3.8.2.2 Configuring Nonbeacon-Enabled Device
    'As above but comment out the line below
    addr = ORDER: gosub ShAddr: outdat = $FF: gosub DataWr
    '(see Section 3.8 “Beacon-Enabled and Nonbeacon-Enabled Networks”):
    '10. BBREG2 (0x3A) = 0x80 – Set CCA mode to ED.
    '11. RSSITHCCA (0x3F) = 0x60 – Set CCA ED threshold.
    '12. BBREG6 (0x3E) = 0x40 – Set appended RSSI value to RXFIFO.
    '13. Enable interrupts – See Section 3.3 “Interrupts”.
    '14. Set channel – See Section 3.4 “Channel Selection”.
    '15. RFCTL (0x36) = 0x04 – Reset RF state machine.
    '16. RFCTL (0x36) = 0x00.
    '17. Delay at least 192 ms.
    addr = BBREG2: gosub ShAddr: outdat = $80: gosub DataWr
    addr = RSSITHCCA: gosub ShAddr: outdat = $60: gosub DataWr
    addr = BBREG6: gosub ShAddr: outdat = $60: gosub DataWr
    addr = INTCON: gosub ShAddr: outdat = 8: gosub DataWr
    addrm = RFCON0: gosub ShAddr: outdat = $82: gosub DataWr 'Channel 19
    addr = RFCTL: gosub ShAddr: outdat = 4: gosub DataWr
    addr = RFCTL: gosub ShAddr: outdat = 0: gosub DataWr
    pauseUS 200 'as per datasheet wait at least 192uS
    For i = 0 To TX_BUFFER_SIZE
    txRadioBuffer[i] = i '0x00 put in some data
    Next
    For i = 0 To RX_BUFFER_SIZE
    rxRadioBuffer[i] = 0
    Next
    SendMessage:
    For i = 0 To 127 'make sure there is valid data in array
    Next
    txDestination = $FFFF ' Set the destination address
    txPayLoad = 16 ' set amount of data to xmitt from array(payload)
    're-write first 11 bytes with hdrLen, frm Len and Header
    '// Compute and send header and frame length
    HeaderLength = 9 '(index 2 to 10, 9 bytes)
    FrameLength = HeaderLength + txPayLoad '9 (0-8)+ 16 (0-15) = 25
    ''address 0-1 '2 bytes
    txRadioBuffer[0] = HeaderLength
    txRadioBuffer[1] = FrameLength
    txRadioBuffer[2] = FrameControl.LowByte 'framecontrol[0] 0x26
    txRadioBuffer[3] = FrameControl.HighByte 'framecontrol[1] 0x22
    txRadioBuffer[4] = IEEEseqNumber 'IEEEseqNumber++
    txRadioBuffer[5] = $01 'myPANID[0]
    txRadioBuffer[6] = $02 'myPANID[1]
    txRadioBuffer[7] = txDestination.LowByte 'networkTX.dest & 0x00FF
    txRadioBuffer[8] = txDestination.HighByte 'networkTX.dest >> 8
    txRadioBuffer[9] = $cd 'myShortAddress[0]
    txRadioBuffer[10] = $ab 'myShortAddress[1]
    random temp
    txRadioBuffer[11] = temp.Byte0
    IEEEseqNumber = IEEEseqNumber + 1
    wcnt = 0
    'fifo = 0 = i
    For i = 0 To FrameLength +1
    addrm = i: gosub LoAddr: outdat = txRadioBuffer[i]: gosub LDataWr
    Next
    '2. If the packet requires an Acknowledgment, the Acknowledgment request bit in the frame control
    ' field should be set to ‘1’ in the MAC Header (MHR) when the host microcontroller loads the TX
    ' Normal FIFO, and set the TXNACKREQ (TXNCON 0x1B<2>) bit = 1. Refer to Section 3.13 “Acknowledgement”
    ' for more information about Acknowledgment configuration.
    addr = TXSTAT: gosub ShAddr: gosub DataRd
    outdat = indat or 192 'bit 6 and 7 = 1
    addr = TXSTAT: gosub ShAddr: gosub DataWr
    '3. If the frame is to be encrypted, the security enabled bit in the frame control field should be
    ' set to ‘1’ in the MAC Header (MHR) when the host microcontroller loads the TX Normal FIFO,
    ' and set the TXNSECEN (TXNCON 0x1B<1>) bit = 1. Refer to Section 3.17 “Security” for
    ' more information about Security modes.
    '4. Transmit the packet by setting the TXNTRIG (TXNCON 0x1B<0>) bit = 1. The bit will be
    ' automatically cleared by hardware.
    addr = TXNCON: gosub ShAddr: gosub DataRd
    outdat = indat or 5 'bit 0 and 2 = 1
    addr = TXNCON: gosub ShAddr: gosub DataWr
    SendMessage1:
    '5. A TXNIF (INTSTAT 0x31<0>) interrupt will be issued. The TXNSTAT (TXSTAT 0x24<0>) bit
    ' indicates the status of the transmission:
    'TXNSTAT = 1: Transmission was successful
    'TXNSTAT = 0: Transmission failed, retry count exceeded
    'The number of retries of the most recent transmission is contained in the TXNRETRY
    '(TXSTAT 0x24<7:6>) bits. The CCAFAIL
    '(TXSTAT 0x24<5>) bit = 1 indicates if the failed transmission was due to the channel busy
    ' (CSMA-CA timed out). '// Transmission acknowledgement request
    addr = INTSTAT: gosub ShAddr: gosub DataRd
    if indat.0 = 1 then goto SendMessage1
    tmp = PORTC
    if indat.0 = 1 then
    PORTC = 255
    PORTC = 0
    PORTC = txRadioBuffer[11]
    RecMessage:
    IntStatus = indat
    if INTSTAT and 8 = 8 then return
    '*************receive packet**********************
    getMACframe:
    ' Example steps to read the RXFIFO:
    ' 1. Receive RXIF interrupt. (INSTAT.3)
    ' 2. Disable host microcontroller interrupts.
    ' 3. Set RXDECINV = 1; disable receiving packets off air. (BBREG1.2)
    ' 4. Read address, 0x300; get RXFIFO frame length value.
    ' 5. Read RXFIFO addresses, 0x301 through (0x300 + Frame Length + 2); read packet data plus LQI and RSSI.
    ' 6. Clear RXDECINV = 0; enable receiving packets.
    ' 7. Enable host microcontroller interrupts.
    '// Disable interrupts, disable reception
    ' 'RFIE = 0;
    addr = BBREG1: gosub ShAddr: outdat = $04: gosub DataWr
    bRetVal = 0
    addrm = RX_FIFO: gosub loAddr: gosub LDataRd
    rxRadioBuffer[0] = indat + 2
    For i = 1 To rxRadioBuffer[0]
    addrm = (RX_FIFO + i): gosub loAddr: gosub LDataRd
    rxRadioBuffer[i] = indat
    Next
    addr = BBREG1: gosub shAddr: outdat = $00: gosub DataWr
    PORTC = rxRadioBuffer[11]
    '**************** releaseRXbuffer *************
    releaseRXbuffer:
    'INT2IE = 0 'disable interrupt
    addr = RXFLUSH: gosub shAddr: outdat = $01: gosub DataWr 'flush buffer
    addr = RXMCR: gosub shAddr: outdat = $00: gosub DataWr 're-enable Ack response
    'radioStatus_rxFifoHasData = 0 'reset
    'rxsize = 0 don't have yet
    'INT2IE = 1 'enable interrupt
    ShAddr:
    cs = 0
    pauseus tlong
    sdi = 0
    sck = 1
    pauseus tmid
    sck = 0
    for tmp = 0 to 5
    sdi = addr.5
    sck = 1
    pauseus tmid
    sck = 0
    addr = addr << 1
    pauseus tmid
    next tmp
    LoAddr:
    cs = 0
    pauseus tlong
    sdi = 1
    sck = 1
    pauseus tmid
    sck = 0
    for tmp = 0 to 9
    sdi = addrm.9
    sck = 1
    pauseus tmid
    sck = 0
    addrm = addrm << 1
    pauseus tmid
    next tmp
    DataRd:
    sdi = 0
    sck = 1
    pauseus tmid
    sck = 0
    indat = 0
    for tmp = 0 to 7
    sck = 1
    pauseus tmid
    indat = indat + sdo
    sck = 0
    indat = indat << 1
    pauseus tmid
    next tmp
    cs = 1
    DataWr:
    sdi = 1
    sck = 1
    pauseus tmid
    sck = 0
    'Read data
    indat = 0
    for tmp = 0 to 7
    sdi = outdat.7
    sck = 1
    pauseus tmid
    sck = 0
    outdat = outdat << 1
    pauseus tmid
    next tmp
    cs = 1
    LDataRd:
    sdi = 0
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    indat = 0
    for tmp = 0 to 7
    sck = 1
    pauseus tmid
    indat = indat + sdo
    sck = 0
    indat = indat << 1
    pauseus tmid
    next tmp
    cs = 1
    LDataWr:
    sdi = 1
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    sck = 1
    pauseus tmid
    sck = 0
    indat = 0
    for tmp = 0 to 7
    sdi = outdat.7
    sck = 1
    pauseus tmid
    sck = 0
    pauseus tmid
    next tmp
    cs = 1
    Maybe someone can point me in the right direction......................
    Thanx
  1. PIC18LF13K50 Extremly low power counter
    By pedja089 in forum mel PIC BASIC Pro
    Last Post: - 17th October 2010, 02:01
  2. Replies: 0
    Last Post: - 29th August 2008, 14:55
