Bluetooth module for Ipod?
Results 1 to 4 of 4
    Default Bluetooth module for Ipod?
    Hello Guys,
    I want to create a small circuit with a 16F88 PIC and a few relays.
    Also, I want to interface that PIC to a bluetooth module. Something like this:
    But, I was wondering if anyone successfully tried this with a bluetooth module and an Ipod?
    I got a bluetooth module from eBay and the Ipod doesn't even see it! But, a phone with Android does and it works!
    So, before I try every single module out there until one works, I prefer to ask here first if someone has already tried it.
    Thanks!
    Daniel.
    Default Re: Bluetooth module for Ipod?
    Hi Daniel,
    I have used the very common modules available on Ebay, the ones that show up as 'Linvor' by default. Could you give more information on the one you have?
    If you just power them up, without even connecting them to a micro, they show up on an Android for sure.
    And sure, they work great with pics. The range is a bit modest, though.
    Remember they are 3.3 volt devices, unless you buy the ones mounted on a pcb with a 3.3 volt LDO, in which case they can be powered from 5 volts. The USART pins are still 3.3, though.
    Yes, that's the one I have. The one that comes mounted on the PCB.
    Yes, they do! But, I found Apple uses a custom authentication process and not every bluetooth module will work. Check the ones from www.rovingnetworks.com for more information, but those are crazy expensive! Apple requirements to work with bluetooth devices are plain stupid from every single point of view, but I'm stuck with them.
    Enough for my application, a wireless custom LED controller.
    That's right!
    Quote Originally Posted by danielhr77 View Post
    Ah, one learns!
    As one who keeps away from all Apple products, I had no idea they'd do this to something as basic as b/t comms. Sure dont envy your task!
  1. Bluetooth Module, SKKCA-21, Cytron
    By arson88 in forum Bluetooth
    Last Post: - 19th March 2012, 16:44
  2. Bluetooth module @ 3.3 volts
    By ardhuru in forum Bluetooth
    Last Post: - 22nd January 2012, 04:09
  3. ipod or Iphone to picbasic
    By robertg in forum mel PIC BASIC Pro
    Last Post: - 14th August 2011, 20:55
  4. What bluetooth module to choose?
    By mbox in forum mel PIC BASIC Pro
    Last Post: - 8th November 2009, 23:01
  5. win iPod
    By Ivasi in forum Off Topic
    Last Post: - 18th August 2004, 15:15
