same code example as u wanted but without the comments is
Code:DEFINE OSC 8 ' Timing referance for pause , pauseus commands H9 var PORTB.0 ' Port B.0 is output pin digital TTL H9 = 0 ' Set output to low on startup can remove and assume it 0 to start but hey Main: H9 =1 :pause 10 :H9=0: pause 10 goto main
