pic+shift register+lcd
Results 1 to 3 of 3
    Oct 2012
    Default pic+shift register+lcd
    Hi guys
    I am using pic12f675 and a shift register from 74 series. I don't know why my shift register doesn't do anything. I am sure that the program is wrong but I can not find any sample program in pbp that used a shift registre (74ls794).I am not sure if the problem is about the clock or it's just about the IC . Here is the code:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _PWRTE_OFF & _BODEN_OFF
    INCLUDE "modedefs.bas" ' Include serial modes
    TRISIO = %11010000
    OPTION_REG.7=0 ' Enable pull-ups
    WPU=%00010000 ' Enable pull-ups on GP0, GP1,GP4
    CMCON=%00000100
    VRCON=%10100000
    ANSEL=0
    ' Define LCD connections
    DEFINE LCD_CLK GPIO.1
    DEFINE LCD_D GPIO.2
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG GPIO
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG GPIO
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG GPIO
    DEFINE LCD_EBIT 0
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_LCDUS 50
    PAUSE 500
    SEROUT GPIO.2,N2400,[$FE,1]
    PAUSE 50
    SEROUT GPIO.2,N2400,["HELLO,",10,13]
    PAUSE 50
    SEROUT GPIO.2,N2400,["WORLD,",10,13,10,13]
    PAUSE 500
    GOTO Main
    Default Re: pic+shift register+lcd
    The 74ls794 is not a shift register and the SHIFTIN/SHIFTOUT command is commonly used with shift registers.
    Oct 2012
    Hi
    I am sorry ,It was my mistake, the shift register is 74ls194 and thank you for reply.I'll test shiftout command.
  1. weird problem with dot matrix and shift register
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 6th November 2010, 20:00
  2. Long shift register
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 18th April 2009, 20:14
  3. Replacing shift register with PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 19:31
  4. Shift Register Woes, specifically the STP16DP05
    Last Post: - 12th November 2007, 00:22
  5. Replies: 15
    Last Post: - 30th January 2005, 04:58
