Working with Cosine
Results 1 to 3 of 3
    i'll suggest you something else, take a few reading of your signal with the internal adc, store those data into array or internal EPROM and play with. Refering to a table will be much easier and much code efficient. BUT it's my own opinion, probably Melanie or somebody else have a better solution.
    Wink
    Hi,Ed
    You'll get -127 to +127 as a result ... so, look at the highest digit to see where you are on your sine ( ascending = 1, descending = 0 ).
    But do not forget to convert degrees as here:
    Result = COS ( X * 256 / 360 ) ... for X in degrees.
    Side = Result.7
    Looking also to SIN highest digit will show you the quarter where you are ...
    For accuracy ... 7 bits !!!
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 16:04
  2. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 04:36
  3. Pic 16 F628A not working
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 13:26
  4. Wrong values with COSINE!
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 17:59
  5. Hserin not working...
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 13:25
