Bit order for HSEROUT[A]
Results 1 to 2 of 2
    Default Bit order for HSEROUT[A]
    I have scanned the PIC18F4620 datasheet and the PBP3 manual and I can't find a description of the bit order used by the HSEROUT [A] command. Does it send A.0 first or A.7? I know I could set up a quick piece of test code but I am away from my development system right now.
    Thank you
    BrianT
    Default Re: Bit order for HSEROUT[A]
    I think the easiest way to gleen that information from the datasheet is to look at the USART's block diagram.
    Data is shifted out in the direction of the red arrow.
  1. Reverse Bit Order?
    By Art in forum General
    Last Post: - 23rd January 2010, 23:52
  2. Large-ish PCB order...others wanted...
    By skimask in forum Off Topic
    Last Post: - 16th June 2006, 03:43
  3. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
  4. bit order inverting
    Last Post: - 28th July 2005, 04:37
