Create a label which point to an instruction
Results 1 to 8 of 8
    Jan 2008
    lincoln uk
    Default Create a label which point to an instruction
    How do I create a short cut to an instruction in PBP such as
    H9 means or points to instruction like HIGH PORTB.0 ?
    So instead of writing HIGH PORTB.0: PAUSE 10 : LOW PORTB.0
    I can write H9: PAUSE 10: H9 ??
    Cheers
    Michael
    Oct 2009
    Utah, USA
    Default Re: Create a label which point to an instruction
    You can create aliases to port.pins like this...
    H9 var PORTB.0
    Then you can do this...
    MAIN:
    HIGH H9: PAUSE 100: LOW H9: PAUSE 100
    GOTO MAIN
    This is detailed in the PBP manual, section 4
    I am not aware of a way to do a macro that will execute several commands... someone else may know a way.
    Dwight
    Quote Originally Posted by med2007 View Post
    Cheers
    Michael
    your idea is somewhat complicated ... till PBP already does it !!!
    PULSOUT PortB.0, 100 ' 100 @ 4Mhz or 500 @ 20Mhz
    or
    H9 var PORTB.0 ' in the header
    PULSOUT H9,100 ' 100 @ 4Mhz or 500 @ 20Mhz
    soo simple, when opening the Holy manual
    Jan 2008
    lincoln uk
    Thanks for the insight, however I want to say...
    H9 : pause 10 ...... not HIGH H9 pause 10 .... and achieve same result
    I want H9 to mean HIGH PORTB.0
    I am old and frail and need help.
    Michael
    I'm curious why the GOSUB command does not suit your needs.
    Do you want to substitute just that one command? If so, you are creating a lot of overhead for something really small.
    If it's because you want to keep things extra simple in your code, what about clear comments? My memory is no longer what it used to be so I include a LOT of comments in my code. Comments do nothing to your program; they take no space and do not affect performance.
    Jan 2008
    lincoln uk
    I am frail, old and grey and have lost my book.
    Here it is again; I think I have not formed the question correctly.
    I want to convert:
    HIGH PORTB.0 : PAUSE 10 : LOW PORTB.0 : PAUSE 10
    GOTO main
    to
    H9 : PAUSE 10 : LOW H9 : PAUSE 10
    GOTO main
    ?? Can I precede the code with H9 VAR HIGH PORTB.0 ??
    Michael
    It has temporarily disappeared into a QBH, Quantum Black Hole, which I find abound in my locality.
    Feb 2012
    PERTH AUSTRALIA
    not sure if this what you want but if i am reading this correctly the code might be the following ,
    Assumptions that is taken for the following example code are
    1.digital ports have been set in config not analog
    2. the OSC type is defined in config correct value , assumed to be 8Mhz in example ,
    3. the port is setup for output in config eg TRISB = %00111100
    4. the port used is able to be output not input only
    5. correct setting of week pullups is set
    6. the output pulse is expected to be a digital output not varable analog
    7. other external ccts not effect current drain on output etc
    8, that other code required in pic will not stop the loop
    This code only creates a square wave pulse of 10Ms high and 10ms low during its continued execution ,and thats fine as long as thats all its going to do and no other program needs to be called else it will stop
    to make it clearer and to get what you end up wanting it would help if you advised the chip type ,and associated ccts and what the end goal is
    but given these assumptions above
      DEFINE OSC 8             ' Timing referance for pause , pauseus commands
     H9 var PORTB.0            ' Port B.0 is output pin digital TTL
    H9 = 0                           ' Set output to low on startup
    H9 =1             ' Set output to high
    pause 10         ' allow it to be high for 10ms
    H9=0              ' set output to low
    pause 10        ' allow pulse low for 10ms
    regards
    Sheldon
    Feb 2012
    PERTH AUSTRALIA
    same code example as u wanted but without the comments is
    H9 = 0                           ' Set output to low on startup can remove and assume it 0 to start but hey
    H9 =1   :pause 10 :H9=0: pause 10
  1. Replies: 5
    Last Post: - 12th September 2011, 08:51
  2. I wish to create an article for the WIKI
    By Normnet in forum Forum Requests
    Last Post: - 5th January 2011, 04:12
  3. How do you create a lookup table?
    By AlexanderWinnig in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 14:37
  4. pic16f88, xbee's & point-2-point comms
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2009, 08:43
  5. How to create multidimensional Array
    By jiunn82 in forum mel PIC BASIC Pro
    Last Post: - 5th February 2007, 18:23
