Did you get the main program structure working?
If it still acts funny, it's probably because the GOTO MAIN in the subroutines always goes back to the top of the program. Only SUB1 will get executed.
What about something like this?
I would recommend starting with Port B for your testing. You can use Port A later once you have a simple program working.Code:GOTO MAIN ' Skip over subroutines Sub1: high portB.0 RETURN Sub2: high portB.1 RETURN Sub3: high portB.2 RETURN MAIN: GOSUB Sub1 GOSUB Sub2 GOSUB Sub3 END
