Moving Average and DIV32
Results 1 to 6 of 6
    Default Moving Average and DIV32
    Hello all,
    I'm trying to calculate the the moving average of a word size variable. The formula I'm using is listed below and is standard as far as I can tell. New values of watts are added to the average when a counter is incremented by 1 in my program.
      wattsAvg = (wattsAvg*counter + watts)/(counter + 1) 'moving average of watts
    The results obtained are correct as as long as the numbers stay within word size limits. However, that is not the case as my numbers can range as follows:
    counter : 0 to 400
    watts : up to 7500 max
    I think the problem would be solved with longs, but these require an 18F part. I'm using a 16F1823 as I need very small size device. I tried DIV32 as follows;
      dummy = wattsAvg*counter + watts
      wattsAvg = div32 (counter + 1)
    This does not work. Apparently you cannot mix multiplication and addition on the dummy line. The result is always zero.
    Grateful for any ideas.
    May 2008
    Italy
    Default Re: Moving Average and DIV32
    Since you are averaging then it does not make any difference if you do your calculation on the whole number or on the difference from the average. Flag if the difference is negative, so you will know that it will be a subtraction and work with the difference, that being smaller will never overflow your word.
    Cheers
    Al.
    With a little help from our Friend Darrel ...
    ' This routine will keep a "Running Average"
    ' Instead of adding a bunch of values together and then dividing by the number of samples,
    ' it averages each sample into the final result immediately.
    ' This eliminates the need for 32 bit math.
    ' To allow it to "Catch up" to large changes, set the FAspread to an acceptable range.
    ' Simply place the new number in VALUE and GoSub AVERAGE
    ' The Average will be returned into the same variable VALUE
    AvgCount	CON  16		' = Number of samples to average
    FAspread	CON  1000	' = Fast Average threshold +/-
    ADavg		VAR  WORD
    Value		VAR  WORD
    ' -=-=-=-=-=-=  Average Analog values -=-=-=-=-=-=-=-=-=-=
    Average:
        IF Value = ADavg Then NoChange
        IF ABS (Value - ADavg) > FAspread OR Value < AvgCount Then FastAvg
        IF ABS (Value - ADavg) < AvgCount Then RealClose
        ADavg = ADavg - (ADavg/AvgCount)
        ADavg = ADavg + (Value/AvgCount)
        GoTo AVGok
      FastAvg:
        ADavg = Value
        GoTo AVGok
      RealClose:
        ADavg = ADavg - (ADavg/(AvgCount/4))
        ADavg = ADavg + (Value/(AvgCount/4))
      AVGok:
        Value = ADavg			' Put Average back into Value
      NoChange:
    found here: http://www.pbpgroup.com/modules/wfse...hp?articleid=7
    Guys,
    This seems to work per your suggestions:
      if watts = wattsAvg then
      wattsAvg = watts
      if watts > wattsAvg then
      wattsAvg = wattsAvg + (watts - wattsAvg)/(counter + 1)
      if watts < wattsAvg then
      wattsAvg = wattsAvg + (wattsAvg - watts)/(counter + 1)
    Disregard my last post. Upon retest the code shown did not work.
    Please disregard this whole inquiry. I'm going down the wrong track.
  1. Replies: 6
    Last Post: - 1st November 2011, 18:53
  2. DT Average
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 6th October 2011, 23:47
  3. Replies: 1
    Last Post: - 11th June 2011, 08:22
  4. Average Values and digital filter ...
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 12:29
  5. Math help - rolling average Wind Direction
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 00:08
