L298N Motor Driver using pwm code not working..
Results 1 to 15 of 15
    Jun 2011
    Philippines
    Default L298N Motor Driver using pwm code not working..
    Hi, I know I have unfinished topic in another thread, but I'm still waiting some parts to come, so I decided to move on to my simple mobile robot structure. The sensors mentioned from the other thread are going to be placed on this three wheeled robot. But I hit another brick wall. I've been losing my head since this morning..it's 2Am now already . I hope anybody can help me out..I'm having trouble driving the motors using PWM. When not using the PWM, motors work great...please see image\schematic below.
    Attachment 6682
    My setup
    Attachment 6684
    My codes:
    Define OSC 20
    ANSEL=%00000000
    ANSELH=%00000000
    TRISC = 0
    PORTC = 0
    TRISD = 0
    PORTD = 0
    MainLoop:
    PortD.0 =1
    PortD.1 =0
    PortD.2 =1
    PortD.3= 0
    PortC.4 ,127, 100
    PortC.5 ,127, 100
    Goto MainLoop
    Can any one spot what I'm doing wrong...I appreciate any input.
    Kind regards,
    tacbanon
    Default Re: L298N Motor Driver using pwm code not working..
    That code looks just wrong.
    You set four outputs on PortD while the schematic shows PortC.
    Then you seems to missing the actual PWM statement, and if you meant to PWM the Enable pins you have those too on the wrong pins.
    I'm surprised if that code even compiles.
    Jun 2011
    Philippines
    Hi Henrik,
    My bad, uploaded the wrong image(must be very tired last night)
    [ATTACH=CONFIG]6686[/ATTACH
    Thanks for the replying...I will try it today and post here my output.
    ..aren't pin5 and pin6 the PWM pins on JP6?
    /tacbanon
    Jun 2011
    Philippines
    Hi, kindly check if this should be the right pins assignment.
    PortD.0 to input3 of l298
    PortD.1 to input4 of l28
    PortC.0 to enable of l298
    by henrik: I'm surprised if that code even compiles.
    Really sorry..next time I will double check before uploading.
    PWM PORTD.0, 127,100
    PWM PORTD.1, 127,100
    PortC.0 = 1
    Hope I'm close...
    /tacbanon
    Concentrate on one bridge and motor to begin with, when you have that working apply the same procedure to the second bridge/motor.
    Bridge 1 is controlled In1, In2 and ENA - in your case (according to your latest schematic) PortD.0, PortD.1 and PortC.4 respectively.
    To drive the motor forward you drive PortD.0 high, PortD.1 low and apply the PWM signal to PortC.4
    PortD.0 = 1
    PortD.1 = 0
    For i = 0 to 200              ' Ramp up.
       PWM PortC.4, i, 10
    NEXT
    For i = 200 to 0 Step -1  ' Ramp down.
       PWM PortC.4, i, 10
    NEXT
    Pause 500
    Goto Main
    According to the photo of the board there are a jumper for each bridge which says Remove jumper for PWM - did you do that? If you didn't the EN-pins are tied high and will short your PWM signal to the boards Vcc.
    Jun 2011
    Philippines
    Thank you Henrik for saving me hours of time just to make it ...I got it finally! I will try to add the other bridge, then post here my result.
    regards,
    tacbanon
    Jun 2011
    Philippines
    Default Imrproving motor control in line follower application.
    Hi, I did manage to add the other motor, right now I made as a line tracker robot . Not very well on the curves yet and a little slow..hope you can look onto my codes and might able to improve the performance..
    DEFINE osc 4
    ANSEL = %00000111 ' Make AN0-AN7 Analog
    ANSELH= %00000000 ' Make AN8-AN13 digital
    TRISA  = %00111111
    ADCON1 = %00001001
    TRISC = 0
    TRISD = 0
    TRISB = 0
    ;-------------Variables
    senCenter var byte
    senRight  var byte
    senLeft   var byte
    i var word
    i = 0
    PORTD.0 = 1 ' In1
    PORTD.1 = 0 ' In2
    PORTB.0 = 1 ' In3
    PORTB.1 = 0 ' In4
    ; PORTC.4 PWM Signal
    loop1:
       Adcin 0, senCenter
       Adcin 1, senRight
       Adcin 2, senLeft
       ;Serout2 PORTD.2, 84, [$1B,$45,Dec senCenter," ", DEc senRight," ",Dec senLeft]
       ;------------------------Select options seen by the sensors
       IF senCenter > 150 and senRight > 150  then
           Gosub movExtRight
        Endif
       IF senCenter > 150 and senLeft > 150  then
           Gosub movExtLeft
        Endif
        IF senCenter > 150 then
           ;Serout2 PORTD.2, 84, [$1B,$45]
           ;Serout2 PORTD.2, 84, [$D,"     Center"]
           gosub movForward
        Endif
        IF senRight > 150 then
           ;Serout2 PORTD.2, 84, [$D,"Rigth"]
           gosub movRight
        Endif
        IF senLeft > 150 then
           ;Serout2 PORTD.2, 84, [$D,"           Left"]
           gosub movLeft
        Endif
       ;gosub movForward
    GOTO loop1               ' Do it forever
    movForward: '  forward
    PORTD.0 = 1 ' In1
    PORTD.1 = 0 ' In2
    PORTB.0 = 1 ' In3
    PORTB.1 = 0 ' In4
    PWM PORTC.4 ,200,10
    PWM PORTC.5 ,200,10
    movExtRight: ' turn more to the right
    PWM PORTC.4 ,50,10
    PWM PORTC.5 ,200,10
    movRight: '  short right
    PWM PORTC.4 ,100,10
    PWM PORTC.5 ,200,10
    movLeft: '   short left
    PWM PORTC.4 ,200,10
    PWM PORTC.5 ,100,10
    movExtLeft: ' turn more to the left
    PWM PORTC.4 ,200,10
    PWM PORTC.5 ,50,10
    senLost: ' Getback no line detected
    PORTD.0 = 0 ' In1
    PORTD.1 = 1 ' In2
    PORTB.0 = 0 ' In3
    PORTB.1 = 1 ' In4
    PWM PORTC.4 ,200,5
    PWM PORTC.5 ,200,5
    pause 50
    Thanks in advance,
    tacbanon
    Since you're using the 16F887 which has two CCP-modules the first thing I'd do is the rewire the thing so that the EN-pins of the L298N are connected to PortC.1 and PortC.2 and use HPWM instead.
    That way the PWM generation is handled in the background, by the CCP-modules (instead of tying up the processor) and you only need to update it when you want to change the speed. Your program gets a lot of time to do other things.
    Then I'd probably set up a timer interrupt to trip every 25ms or something. In the ISR I'd read the sensors and set the PWM dutycycles accordingly.
    Jun 2011
    Philippines
    Default I can not make it stay on the line
    Hi, I'm back...I got the HPWM working and also the timer. But I can never make the robot stay on track/line . Probably my setup is not right or something...kindly check my codes, hoping you can help me out spot what I'm doing wrong.
    ANSEL = %00000000 ' Make AN0-AN7 Digital
    ;--------- Setup Interrupt--------------------------
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
            INT_Handler   TMR1_INT,  _CheckSensors,   PBP,  yes
    T1CON = %00100001                ; 00110001  Prescaler = 8, TMR1ON
    ;--Setting HPWM
    TRISC.1 = 0 'Set CPP2 to PWM output
    TRISC.2 = 0 'Set CPP1 to PWM output
    CCP1CON = %0001100 ' Set CCP1 to PWM, Active High
    CCP2CON = %0001100 ' Set CCP1 to PWM, Active High
    TRISA  = %00111111 ' did not anymore use this for now
    ADCON1 = %00001001
    TRISC = 0
    TRISD = 0
    TRISB = %10000111 ' 0-2 for sensors
    PortB = %00000000 ' Reset PortB
    OPTION_REG = $7f
    ;--Init variables
    i var Byte
    i = 0 ; 200
    ;-- wheel on forward
    PORTD.0 = 1 ' In1
    PORTD.1 = 0 ' In2
    PORTD.2 = 1 ' In3
    PORTD.3 = 0 ' In4
    ;-------------------Speed of motor--
    Gear var byte[10]
    ;--Set allowable speed---
    Gear[1] = 0
    Gear[2] = 75 ' start slow roll
    Gear[3] = 80
    pause 2000
    i = 2
    MainLoop:
     ;pause 100
    ; Start rolling
    HPWM 1 ,Gear[i],10
    HPWM 2 ,Gear[i],10
    GOTO Mainloop               ' Do it forever
    CheckSensors:
    if PortB.0 = 1 and PortB.2 = 0 then ' Left sensor
       HPWM 1 ,Gear[3],10
       HPWM 2 ,Gear[2],10
       pause 20
       ;Serout2 PORTB.6, 84, [$D,"Right           "]
    if PortB.1 = 1 and PortB.2 = 0 then ' Right sensor
       HPWM 1 ,Gear[2],10
       HPWM 2 ,Gear[3],10
       ;Serout2 PORTB.6, 84, [$D,"            Left"]
       pause 20
    if PortB.2 = 1 and PortB.0 = 0 and PortB.1 = 0  then  ' Center sensor
       i = i + 1
       if i > 2 then
       i = 3
       ENdif
       ;Serout2 PORTB.6, 84, [$D,"    Center      "]
    ;-------------------More than 1 sensors detected
    if PortB.0 = 1 and PortB.2 = 1 then ' Left and Center sensor
       HPWM 1 ,Gear[3],10
       HPWM 2 ,Gear[3],10
       ;Serout2 PORTB.6, 84, [$D,"Right-Center    "]
    Else
    if PortB.1 = 1 and PortB.2 = 1 then ' Right and Center sensor
       HPWM 1 ,Gear[3],10
       HPWM 2 ,Gear[3],10
       Serout2 PORTB.6, 84, [$D,"Center-Left     "]
    Else
    if PortB.0 = 0 and PortB.2 = 0 and PortB.1 = 0 then ' Can't see no line
       ;HPWM 1 ,Gear[0],10
       ;HPWM 2 ,Gear[1],10
       Serout2 PORTB.6, 84, [$D,"No more line?   "]
       pause 50
       Serout2 PORTB.6, 84, [$D,"Error???         "]  ' Others
    ENdif:ENDIF:ENDIF:ENDIF:ENDIF:ENDIF
    @ INT_RETURN
    Thank you in advance,
    tacbanon
    I don't really follow your coding but you have a main loop which constantly (I mean thousands of times per second) keeps setting the dutycycle to some value. When the interrupt fires, decide which way to turn (if any) and set the dutycycle, don't change it the main loop. BTW, does 10Hz really work? Also, in your previous code I got the impression that the sensors were analog (you used ADCIN to read them) but now they are digital?
    EDIT: One more thing, you don't seem to reload the timer value in the ISR.
    Since the timer is freerunning and generating an interrupt on overflow, with a prescaler of 8 and a 4MHz x-tal the interrupt frequency of 4000000/4/8/65536=1.9Hz, I think you need to run faster than that.
    Jun 2011
    Philippines
    Hi Henrik, thanks you for your comments..I guess I have to rearrange my codes.
    Does this mean I have to remove this in the main loop..
    ; Start rolling
    HPWM 1 ,Gear[i],10
    HPWM 2 ,Gear[i],10
    and place it in a sub program?
    I did remove the analog reading to digital because I thought it will better...don't you think so?
    Regarding the timer, should this be the value T1CON = %00100001 ?
    I really appreciate for answering my questions..not really all clear to me at this time but I hope I will learn some if not all.
    BTW do you think it is best to have a fix speed instead of changing from time to time?
    regards,
    tacbanon
    HPWM works in the background, once you tell it to output a certain dutycycle with a certain frequency it does that in hardware. There's no need to continously execute the HPWM commands like your doing in your main loop.
    If you change the prescaler to 1:1 you'll get an interrupt every 65536us or around 15Hz, I'd try that as a starting point. If you need faster interrupt rate than that you need to preload the TMR1 register in the ISR so that it doesn't start from 0. If you load with 55536 there will be 10000 cycles (or 10000us in this case) untill the next interrupt.
    I have no idea if analog or digital sensor is best. I don't even know what sensors you're using....
    If you have two sensors, one on "each side" of the line then I think two speeds for each motor should do. Run both motor at the lower speed to go straight forward, increase the speed of one motor to turn. (Or do the oposite if you want).
    Jun 2011
    Philippines
    Hi, thanks...I will try your suggestions regarding the timer/interrupt implementation...but I still don't get what you meant HPWM working on the background...my question probably is how I can change the speed parameter if I needed?
    speedR var byte
    speedL var byte
    speedR = 150
    speedL = 150
    pause 2000
    HPWM 1 ,speedR,10 ' Right Wheel
    HPWM 2 ,speedL,10 ' Left wheel
    Mainloop:
    speedR = 100 ' new value of speed
    speedL = 150 '
    Goto Mainloop
    regards,
    tacbanon
    To change the speed you to execute the HPWM command. What I'm "objecting" against is this:
    HPWM.....
    HPWM.....
    Goto Main
    When you do it this your trying to update the PWM generator thousands of time per second. What happens when you update it faster then the frequency it's outputting? I don't know the answer.
    In the ISR, determine what duty cycles to send to each motor and execute the HPWM command there. That way you'll update the speed once each interrupt instead of thousands of times per second.
    Jun 2011
    Philippines
    Default Re: L298N Motor Driver using pwm code not working..(Solved)
    Hi Henrik...many thanks for the kindly explaination...appreciate it very much...got it now.
    regards,
    tacbanon
  1. Replies: 2
    Last Post: - 7th August 2012, 16:16
  2. Motor driver problem w/ HPWM
    By Amoque in forum General
    Last Post: - 21st May 2011, 20:51
  3. L293 motor driver options?
    By Ron Marcus in forum Off Topic
    Last Post: - 5th December 2006, 15:39
  4. Stepping motor Driver
    By mesamune80 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2006, 04:36
  5. Driver code for 14 segment LED display
    By Durward Searcy in forum mel PIC BASIC Pro
    Last Post: - 12th December 2004, 20:08
