Problem with project with pic
Results 1 to 4 of 4
    Aug 2008
    Cool Problem with project with pic
    hello
    My project works fine in proteus
    the more real it does not work
    can someone tell me
    here is the program
    thank you
    TX:
    @ DEVICE PIC16F876A
    @ DEVICE PIC16F876A, WDT_off
    @ DEVICE PIC16F876A, PWRT_ON
    @ DEVICE PIC16F876A, PROTECT_off
    @ DEVICE PIC16F876A, XT_OSC
    DEFINE OSC 4 ' DEFINE OSCILADOR EM 4MHz
    DEFINE HSER_TXSTA 20h ' ABILITA TX , BRGH = 0
    DEFINE HSER_BAUD 2400 ' SETA BAUD RATE
    DEFINE HSER_SPBRG 25 ' 2400 BAUD @ 4MHz, 0,17%
    DEFINE HSER_CLROERR 1 ' LIMPA OVERFLOW AUTOMATICAMENTE
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    CMCON=7
    DEFINE ADC_BITS 10 ' ADCIN resolution (Bits)
    DEFINE ADC_CLOCK 1 ' ADC clock source (Fosc/8)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    PORTA=0
    TRISA=%00000111
    PORTB=0
    TRISB=0
    ADCON1=%11000000
    RAWA VAR WORD
    RAWB VAR WORD
    TOPA VAR word
    TOPB VAR WORD
    AOHM VAR BYTE
    BOHM VAR BYTE
    I VAR BYTE
    REL VAR BYTE
    LCDOUT $fe,1, " By Cesar"
    pause 2000
    START:
    TOPA=0
    FOR I=0 to 19
    ADCIN 0, RAWA
    PAUSEUS 50
    TOPA=TOPA+RAWA+1
    NEXT
    RAWA=TOPA/20
    AOHM=RAWA*/25
    TOPB=0
    FOR I=0 to 19
    ADCIN 1, RAWB
    PAUSEUS 50
    TOPB=TOPB+RAWB+1
    NEXT
    RAWB=TOPB/20
    BOHM=RAWB*/25
    LCDOUT $fe,2,"ADC=",dec3 AOHM," TX1"
    lcdout $fe,$C0,"ADC=",dec3 BOHM," TX2"
    HSEROUT [AOHM,BOHM]
    GOTO START
    RX:
    @ DEVICE pic16F628A
    @ DEVICE pic16F628A, WDT_OFF
    @ DEVICE pic16F628A, PWRT_OFF
    @ DEVICE pic16F628A, BOD_OFF
    @ DEVICE pic16F628A, PROTECT_OFF
    @ DEVICE pic16F628A, MCLR_OFF
    @ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT
    CMCON = 7 'PortA digital
    TRISB =%00000010
    PORTB =%00000010
    TRISA = 0
    PORTA = 0
    DEFINE OSC 4 'DEFINE OSCILADOR EM 4MHz
    DEFINE HSER_RCSTA 90h 'ABILITA RX
    DEFINE HSER_BAUD 2400 'SETA BAUD RATE
    DEFINE HSER_SPBRG 25 '2400 BAUD @ 4MHz, 0,17%
    DEFINE HSER_CLROERR 1 'LIMPA OVERFLOW AUTOMATICAMENTE
    AOHM VAR BYTE
    BOHM VAR BYTE
    REL VAR BYTE
    INICIO:
    hSERIN [AOHM,BOHM]
    if (AOHM>55) THEN
    PORTB.4 = 1
    PORTB.5 = 0
    PORTB.6 = 0
    PORTB.7 = 1
    IF (AOHM<45) THEN
    PORTB.4 = 0
    PORTB.5 = 1
    PORTB.6 = 1
    PORTB.7 = 0
    PORTB.4 = 0
    PORTB.5 = 0
    PORTB.6 = 0
    PORTB.7 = 0
    IF (BOHM>55) THEN
    PORTB.4 = 1
    PORTB.5 = 0
    PORTB.6 = 1
    PORTB.7 = 0
    IF (BOHM<45) THEN
    PORTB.4 = 0
    PORTB.5 = 1
    PORTB.6 = 0
    PORTB.7 = 1
    PORTB.4 = 0
    PORTB.5 = 0
    PORTB.6 = 0
    PORTB.7 = 0
    GOTO INICIO
    Default Re: Problem with project with pic
    What's it supposed to do and what DOES it do?
    Does it work at all, what works, what doesn't?
    Things like that would be some pretty useful information for anyone trying to help.
    My first GUESS, since you say it works in the simulator, is a problem with the oscillators(s). If I'm not mistaken Proteus doesn't actually simulate the oscillator, you just tell it a frequency and it runs at that. In real life things are not perfect and the oscillator, especially the internal one the '628, might be off in frequency enough to cause i mismatch in the baudrate timing.
    If your outputs on the receiver doesn't act the way you expect them to then my vote goes to a read-modify-write issue. Your clock frequency is quite slow and RMW issues usually shows up at much higher frequencies but perhaps you have your outputs heavily loaded?
    Aug 2008
    hello Henrik
    I'll put an external crystal in PIC16F628A
    I will do this
    you think you have problem in codes
    a hug
    thank you
    Aug 2008
    hello
    Today I did as you said with external crystal
    not worked
    I'll see what's wrong
    thank you
  1. Strange problem with an 18F4580 based project
    Last Post: - 19th December 2010, 10:45
  2. Problem with SMS Project: Using 16F877A
    Last Post: - 22nd October 2009, 02:33
  3. Help with PIC project
    By davekav in forum General
    Last Post: - 17th April 2008, 23:15
  4. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 02:52
  5. First Project
    By Andy M in forum General
    Last Post: - 18th August 2004, 20:10
