Calling Macro After Cross Page Boundry
Results 1 to 8 of 8
    Default Re: Calling Macro After Cross Page Boundry
    Have you tried putting your vars all in bank 0 ?
    Feb 2011
    Michigan, USA
    O.K. I'll try that tomorrow. (I don't have chip with me now)
    thanks,
    Mike
    Feb 2011
    Michigan, USA
    Archangel,
    No luck there. I just got a blank screen. I put all all my vars in Bank 0 like following example:
    posX var byte BANK0 SYSTEM
    I can get it to work if i manually do everything. But the macro would sure be nice.
    Mike -
    Feb 2011
    Michigan, USA
    Got it working.
    Changed code in Macro. Removed the local label called OverVar. Not sure why it was there anyway. Also took the gosub LcdGotoXY out of for/next loop since it only needed to be executed once.
    Also put in provision in case the variable number = 0.
    here's updated macro:
    'PrintVar Macro
    'Example: @ PrintVar x,y, _variableName
    asm
    PrintVar macro x, y, variable
        MOVE?CB  x, _posX
        MOVE?CB  y, _posY
        MOVE?WW  variable, _varData
        L?CALL   _VariableOut
    endasm
    VariableOut:
        zeroFlag = 0
        gosub LcdGotoXY
        'cycle through all possible digts of word sized number
        for n = 4 to 0 step -1
            lcdData = (varData dig n) + 48
            if lcdData = 48 AND zeroFlag = 0 then SkipNum
            zeroFlag = 1
            gosub LcdSendChar
            posX = posX + 6
    SkipNum:
    		'if varData = 0 then print "0"
    		if n = 0 AND zeroFlag = 0 then
            	gosub LcdSendChar
        next
