Using "If then" and "and" together
Results 1 to 7 of 7
Threaded View
  1. #4
    Default Re: Using "If then" and "and" together
    Using PBP 2.60C, MCSP v2.2.1.1, MPASM v5.46, PIC 18F46K22.
    62 bytes:
    @   __CONFIG    _CONFIG1H, _FOSC_HSHP_1H & _PLLCFG_OFF_1H & _PRICLKEN_OFF_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @   __CONFIG    _CONFIG2L, _PWRTEN_ON_2L & _BOREN_SBORDIS_2L & _BORV_285_2L
    @   __CONFIG    _CONFIG2H, _WDTEN_OFF_2H
    @   __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _HFOFST_OFF_3H & _MCLRE_EXTMCLR_3H
    @   __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    DEFINE OSC 20
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %10000000
    TRISE = %00000000
    CODE_ONE        VAR PortB.1
    CODE_TWO        VAR PortB.2
    CODE_THREE      VAR PortB.3
    CODE_FOUR       VAR PortB.4
    CODE_FIVE       VAR PortB.5
      IF CODE_ONE = 13 THEN
        IF CODE_TWO = 13 THEN  'With an oh
          IF CODE_THREE = 16 THEN
            IF CODE_FOUR = 21 THEN
              IF CODE_FIVE = 32 THEN
                'Correct code
    138 bytes:
    DEFINE OSC 20
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %10000000
    TRISE = %00000000
      IF CODE_ONE = 13 and CODE_TWO = 13 and CODE_THREE = 16 and CODE_FOUR = 21 and CODE_FIVE = 32 THEN
        'Correct code
    I know, Port be is defined as output and used as input (noticed after test), but that has no impact on test significance.
    More than twice as big using single IF, nested IF is definitely more efficient. I remember reading about that somewhere recently too, can't remember where.
